Trans Pan Torque
Like Tree4Likes
  • 2 Post By rsrocket1
  • 2 Post By NitroPT
Old 10 Mar 2020, 09:23 am
Default Trans Pan Torque
Hey Guys, asking for a dude on Allpar. He's replacing the trans fluid and filter on his PT Cruiser and is going to use a new pan with a drain plug. It came with a rubber gasket and he's wondering if anyone knows the proper torque with the rubber gasket. With regular pan and silicone it's 165 INCH pounds. Anyone know if this is the same with a rubber gasket?
Old 10 Mar 2020, 12:27 pm
rsrocket1's Avatar
Default Re: Trans Pan Torque
I think I used the same setting when I replaced my ATF pan with the one with the drain plug too. The trick was to tighten one bolt on each side and alternate sides so that the pan tightens evenly. There's no pressure trying to blow the gasket out so the torque is only needed to hold the pan in place and hold the bolts in place while filled with ATF.
Carl48 and chuzz like this.
Old 10 Mar 2020, 12:30 pm
Unless otherwise noted by the gasket manufacture all torque related specification are OEM.
LionPT and chuzz like this.
Old 11 Mar 2020, 08:21 am
Thank you, gentlemen. I will relay your responses.
Old 13 Mar 2020, 07:22 pm
I did the pan with a drain plug on my most recent acquisition. Pan was better quality than expected and I found it very handy for a guy like me who drains/refills the fluid 2-3 times when I pick up any used car. No real need to replace the filter for this week-long routine, just the juice.
Bob in Liberty MO
Old 14 Mar 2020, 09:36 am
Bob in Liberty MO
Ya those aftermarket pans are so good I bought two and put them together for one BIG one! lol
I don't need no stinking torque wrench for a Trans pan gasket! gwairbrush General PT Cruiser Discussions 8 22 Apr 2015 06:44 pm
Filled torque struts on the Passenger side, what options are there for Trans side?! SPLNeon Tech & Performance Forum 7 09 Dec 2014 04:06 pm
Replaceing PT cruiser Trans- Prepping trans questions Wiredright Tech & Performance Forum 6 13 Feb 2013 10:59 am
Lug Nut Torque GTSteve Wheels, Tires, Suspension 1 17 Oct 2003 07:28 pm
to torque or not to torque -oil and plugs thinguy Turbo Performance 12 29 Jul 2003 05:10 pm
