Remote Starter or Something else
Old 21 Jun 2020, 11:22 pm
Default Remote Starter or Something else
I was recently cleaning my rear view mirror when behind the mirror I noticed an antenna with a black box. (Images below)
https://imgur.com/NFr73jP
https://imgur.com/9luMRwX
I asked a friend who said he thought it was the antenna for a remote starter.
The antenna has a wire that travels to the drivers side pillar. I bought this car used and got just one key. The dealer never mentioned a remote starter. I looked under the dash and don't see anything that looks like a remote start module. I also tried pressing the lock key three times on the key. I've previously complained about the battery on the PT 2007 draining quick- about 1.5 to 2 weeks of no driving, had everything checked out and came back clear, even replaced the battery to be safe. This might explain why.
Anyone have something like this in on their car? Is it a remote starter antenna, anyone know the brand/ where the module should be?
Old 21 Jun 2020, 11:35 pm
_PTGT03's Avatar
Default Re: Remote Starter or Something else
it could be something like a remote start or an add-on security system like a viper.
Old 23 Jun 2020, 12:09 pm
pawpawdiv9's Avatar
i have a bulldog remote start that came with mine..i had to remove the fuse and not use it as someone nearby at night would be able to crank it up.
The location is under the steering wheel for mine. Pop down the cover directly under the column.
Over the many years, mine had problens dying with it stitting like yours...You gotta DRIVE IT!!! Also the tires will flat spot with it sitting.
2003 PT cruiser (base)
Remote Starter- which one? Mattnben10 Interior Accessories Forum 11 20 Dec 2016 05:20 am
Remote Starter TheDarkAvengerX General PT Cruiser Discussions 9 13 Feb 2012 04:01 pm
remote starter 4SPEED General Turbo Discussions 7 27 Dec 2011 10:10 am
remote starter superpug666 General PT Cruiser Discussions 7 09 Dec 2008 09:47 pm
Remote Starter for 03 GT Indynick General Turbo Discussions 6 22 Dec 2004 03:44 am
