Need help, SOOO BIG's rear squirter stopped working.
Like Tree15Likes
Old 30 Jun 2020, 07:40 am
ptprice's Avatar
Default Need help, SOOO BIG's rear squirter stopped working.
SOOO BIG's a 2005 PT Cruiser. The original equipment rear hatch window squirter stopped working. This has never posed a problem before. Because of a one arm restriction during my Ulnar nerve surgery recovery I haven't driven much or used this function in well over a month.
I need help troubleshooting it. This is what I've tried;
The rear wiper/washer switch works at both stages, activating the rear washer and I can hear it activating the rear pump. So apparently the switch is OK.
Earlier I topped off the reservoir, as always, with the correct Discount Auto washer fluid but it took less than half a pint. So fluid is OK.
The front squirters function correctly. So the front squirters work OK.
The first thing I thought to ask is could it be a blockage in the hose running to the rear? If so, how can it be cleared.
Any other suggestions? Thanks.
Rear hatch hose
Rear hatch squirter
Rear squirter switch
First stage switch
Second stage switch
Front windshield squirt
rockandroller likes this.
SOOO BIG 2005 PT CRUISER, LIMITED EDITION, SIGNATURE SERIES
Cool Vanilla White, 3 Coats. 2.4 DOHC 16V SMPI Eng. Vanity Cover, 4 Spd. Auto Trans. 2.6 Overall Top Gear, Lock-up Torque Converter. PT Chrome Clad 16" X 6" Wheels, P205/55 R16 Cooper Starfire/Solarus tires, Touring Suspension. Chromed Side Spears, Grills, Fuel Filler Door, Door Locks, Handles/guards , PRND3-1 Bezel, Tail Lights, 3/8" Belt Trim, 5 piece bumper trim. Cool Vanilla White shift ball, Leather tilt steering wheel, Cruise Control, Power Mirrors, A/C, Deep Tinted Sun Screen Glass, Power Moon Roof, Fog and Back-Up Lights, Rear Spoiler, Variable Front Wipers W/Washers, Rear Wiper/Washer, Key less Entry. Replacement 2001 Dark Taupe Grey Suede/Leather Trim Seats, Dual Seat Storage Drawers, Drivers Side Power Seat Height Adjust. Full Length Console, Locking Glove Box, Overhead Temperature/Compass Console, Rear Shelf Panel, AM/FM CD GPS Navigation Radio, 6 Premium Speakers. Back up Camera, 7" Monitor.
Old 01 Jul 2020, 04:44 pm
dougs's Avatar
Default Re: Need help, SOOO BIG's rear squirter stopped working.
Hmmm.... an old facecloth and some windex should do it!
Black base 2006 NA, dented front bumper, scratched rear bumper. 2008 Touring, one of 385 red Turbos built in 2008. Limited grill, body-colored mirrors, grab handle deleted, dual-tone horn, shorty antenna.
Old 02 Jul 2020, 10:09 am
pawpawdiv9's Avatar
i usually stick a needle in the port hole to unclogg mine and the direction aim adjustment.
ptprice and dougs like this.
2003 PT cruiser (base)
Old 02 Jul 2020, 11:15 am
ptprice's Avatar
Thanks, I should've thought of that.
Old 02 Jul 2020, 01:15 pm
Haven't had a rear wiper since 2005, never missed it.
dougs likes this.
03 Cranberry Base GT A/S debadged.
Make a fast friend, adopt a greyhound.
Old 02 Jul 2020, 03:59 pm
ptprice's Avatar
With upper hatch trim panel off I removed hose from nozzle.
No fluid flow when switch activated.
Blockage some where else.
Any other suggestions as to where it might be?
Please advise.
Old 03 Jul 2020, 02:13 am
Have you tried blowing air or water in the hose to see if your hose is leaking somewhere??
ptprice likes this.
Old 03 Jul 2020, 07:27 am
ptprice's Avatar
Thanks. These illustrations show the reservoir, pump and hoses under the cowl panels and the hoses in the rear. Somewhere there's a leak or blockage. The majority of the hose to the rear washer nozzle is imbedded and not visible. Conversely the front washers still work. If it is a blockage in the line and not a leak.
as a desperate attempt, could a good solvent like undiluted Awesome added to the washer fluid free a blockage?
Later addition. Here's a photo of the reservoir. No apparent leaks under the cowl.
I've topped off the washer reservoir with some undiluted Awesome solvent.
Tried the rear washer squirter once again. No squirt yet but if that Awesome detergent works
I'm hoping it might break down a possible blockage in the hose to the rear nozzle..
Old 03 Jul 2020, 10:59 pm
rob302's Avatar
I would think if the line was blocked, it would be because it was pinched, not obstructed.
I'd probably use vinegar as a cleaner in your case, I mean it's how you clean coffee makers and IIRC You used water instead of the blue stuff for quite a long time. A PT cruiser baking in the sun in Florida is pretty much a coffee maker
If you disconnect a little squirter and back, Stick the hose in your mouth and suck do you get air or blue stuff?
Old 04 Jul 2020, 07:17 am
ptprice's Avatar
Good ideas Rob.
I'd tried your first suggestion with out success. Nothing came out. But I'll give it another try.
Vinegar might work. I'll add some vinegar to the fluid in the reservoir and see what happens.
Thanks for the suggestions.
2003 rear wiper stopped working & starting issue Whistler General PT Cruiser Discussions 0 13 Jun 2016 05:25 pm
FOB stopped working? ceil99 General PT Cruiser Discussions 2 06 Aug 2015 09:53 am
key fob stopped working twotone General PT Cruiser Discussions 10 17 Jun 2011 05:47 pm
My ac stopped working. Help!!! salena Tech & Performance Forum 3 14 Oct 2009 10:56 pm
