Chrysler PT CRUISER p 304 engine code fix
Like Tree3Likes
  • 3 Post By MJKnight
Old 09 Jul 2020, 08:50 am
MJKnight's Avatar
Default Chrysler PT CRUISER p 304 engine code fix
I have had an miss at idle and an intermittent 304 code for a few months now..So...
I pull #4 plug wire to find the well over half full of oil..Cleaned that up ordered new gaskets for the top cover and plug wires..CEL light went out ...few days later it's back on...So I'm thinking bad plug wires...I get my new wires and gaskets installed(RockAuto)...Still intermittent CEL
P304...So I swap 1&4 plugs reset computer..it's OK for 50 miles..then back on...p304...
So I get my can of carb cleaner start spaying it on the lower intake and the PT stubble and almost dies...
Well bad lower intake gasket...(deteriorated, cracked & brittle)
I replaced the lower intake gasket and o rings on the injectors...Now no codes...
Old 09 Jul 2020, 03:15 pm
Default Re: Chrysler PT CRUISER p 304 engine code fix
If you have that issue then the cover is warped- and dont think a new one will be flat either...
Ultra black the shit out of the well gaskets...top and bottom or it wont work. Others are probably leaking too...
Also you really need to drench the plug boot with b12 carb cleaner- if a drop of oil is in there, it will just spark to the block...
Btw, all members, it really helps us with CRS to also post a quick descrip of the respective code then it would be much easier to help...
Edit, it would help to change the plugs when that happens...but with time and actual combustion, it should clean up...
Think power washing w/ just fuel...
It also contaminates the oil having a dead cylinder...
Old 16 Jul 2020, 04:14 pm
MJKnight's Avatar
The PT is going on 16 years old...
With 93,000 miles
First time for a gasket change,
I believe just the old tired gaskets give up..
Repacked with a new set of Fel-Pro..
Seems to have done the job...
97 degrees here guys...
Steaks on the grill...
Chrysler Radio Code Missing HerrKratzGermany Europe PT Forum 13 09 Sep 2016 01:15 am
I have a 2008 PT cruiser with a check engine light code p0301 Misfire 56,000 miles. Sierranicole19 Tech & Performance Forum 9 04 Dec 2015 06:26 pm
Chrysler Code P0340 PTJake1 Tech & Performance Forum 4 05 Feb 2013 03:51 pm
2002 PT Cruiser Engine Code P 0551 67Shelby05 General PT Cruiser Discussions 4 08 Mar 2011 08:32 pm
Chrysler Paint Code? DeeV-PT General PT Cruiser Discussions 12 09 Mar 2005 06:50 am
