2006 won't start
Like Tree2Likes
  • 2 Post By JoeX
Old 13 Sep 2020, 10:58 am
Default 2006 won't start
I have a 2006 non turbo street cruiser that had sat for a while, battery was dead so I replaced it. Took it out for a ride and went about 5 miles when it started sputtering, no response to throttle and died. Would crank and fire but not start or run. Had a 1/4 tank of gas but thought it might be empty so I came back the next day and added fresh gas but now won't even fire. Just cranks. I do not hear the fuel pump running at the tank but haven't tested the fuel pressure at the fuel rail. Even after shutting down I didn't get any codes show up on a scanner. Scanner did also show the fuel pump relay coming on. I'm leaning toward the fuel pump but does anyone have any other suggestions?
Old 13 Sep 2020, 06:57 pm
Macgyverman1123's Avatar
Default Re: 2006 won't start
I'd definitely test for fuel pressure first. Sounds like a filter or pump. You could check the fuse and try swapping relays first.
-John P.
Go Canes! #TakeWarning
Old 13 Sep 2020, 10:52 pm
Spray a little starting fluid in the intake, if it fires you will know its fuel related. If you find the fuel pump is not working, first check the ground at the pump before you replace it.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
2006 PT Won't start, tried almost everything jbudreau25 Tech & Performance Forum 17 08 Apr 2017 02:26 am
2006 Non Turbo Won't Start TheAmbit General PT Cruiser Discussions 28 12 Nov 2016 11:00 pm
2006 PT Cruiser GT won't start anglii General PT Cruiser Discussions 11 09 Apr 2014 03:50 pm
2006 PT won't start stan Tech & Performance Forum 10 28 Dec 2010 11:55 pm
2006 PT Won't start when it's warm in the cab ericellis Tech & Performance Forum 4 21 Jan 2010 07:48 pm
