Time For A Tune Up?
Like Tree7Likes
  • 3 Post By soonercruiser
  • 2 Post By rcktpwrd
  • 1 Post By Carl48
  • 1 Post By dougs
Old 01 Mar 2021, 08:58 am
dougs's Avatar
Question Time For A Tune Up?
The 2006 NA now has 96,000 miles. The owner's manual says at 90,000 miles, among other 'check this, check that', you should replace the spark plugs. I replaced the spark plugs and wires about 6 years ago at 45,000 miles. The car runs fine. Runs smooth, starts quickly, etc etc. Do I really need to change the spark plugs? One side of my brain says, 'If it ain't broke, don't fix it'. The other side of my brain says, 'Follow the Maintenance Service Schedule as Mr. Chrysler tells you to'. Any thoughts?
Black base 2006 NA, dented front bumper, scratched rear bumper. 2008 Touring, one of 385 red Turbos built in 2008. Limited grill, body-colored mirrors, grab handle deleted, dual-tone horn, shorty antenna.
Old 01 Mar 2021, 01:29 pm
soonercruiser's Avatar
Default Re: Time For A Tune Up?
Sounds like a dilemma that all of us face.
But, if you are garaged and out of the severe weather mostly. I'd be tempted top pull the plugs and inspect.
The computer can adapt over time, even when the spark tips are eroding.
ptprice, dougs and LionPT like this.
Frank, aka SOONERCRUISER,
Old 01 Mar 2021, 04:41 pm
rcktpwrd's Avatar
Cool Re: Time For A Tune Up?
If you are doing the work yourself, sparkplugs are fairly cheap... If paying a shop it could be a bit spendy.
What sparkplugs were installed last time? If regular copper then they are probably due for replacement. If you went with a platinum or similar type then they should be OK to go longer...
podo2000 and dougs like this.
Joel
www.rcktpwrd.com
Old 02 Mar 2021, 07:36 am
If the plugs are copper, the gap will be widened and the electrodes rounded... they should be replaced. If they are platinum, the center electrode on two of the plugs may be worn (the ignition system is a "waste spark" type). Either way, at 6 years and 50K miles, if it were mine the plugs and wires would get changed along with the upper intake manifold gaskets. Just my .02.
dougs likes this.
Old 02 Mar 2021, 11:31 am
dougs's Avatar
Thanks.... I think I will do this... but I will wait till just a bit closer to 100,000 miles, as the car seems to be running fine now. Also, I want to wait till weather is a bit warmer, to reduce the chance of some tube made from plastic or rubber cracking in the cold.... thanks
Carl48 likes this.
Old 02 Mar 2021, 03:30 pm
Much more enjoyable working on the PT in nice weather.
As you may know, you are looking at the timing belt job in the
near future if that has not yet been done.
Old 04 Mar 2021, 02:15 pm
dougs's Avatar
Did it back at 84,000 miles.... along with the usual 'timing belt' stuff ... water pump, seals, etc etc thanks
Tags
spark plug wires, spark plugs, tuneup
finally got the belt on in time! heck yes time for 3m window weld motor mounts mr42ndstblvd Tech & Performance Forum 1 19 Apr 2018 07:35 pm
Older member, long time lurker but first time poster today! zanerwaner Welcome New PT Cruiser Members 18 20 Oct 2014 07:37 pm
Long Time Owner, time for some wheels...Recommendations? chevychad Wheels, Tires, Suspension 12 14 Apr 2014 02:49 pm
Tune up time. Horsehaulin Tech & Performance Forum 3 02 Nov 2012 10:30 pm
First time here, I think I need a tune up shamuu Tech & Performance Forum 9 18 Apr 2008 06:30 pm
