PT Cruiser Forum Car Videos
Custom Wheels
Oil Catch Can
  #11 (permalink)
Old 16 Sep 2004, 12:09 pm
Mike-in-Orange Mike-in-Orange is offline
All that I have seen would need to be fully disconnected and removed in order to empty. For that reason be real picky about where you mount it so you can remove it easily.
  #12 (permalink)
Old 17 Sep 2004, 01:03 am
taikuchin taikuchin is offline
If you use an air compressor oil separator (about $20) the bowl unscrews & can be emptied back into the oil filler tube in less than a minute. Mine gets about half full in a thousand miles.
I have a picture, but evedently pictures from other PT sites aren't welcome here....
http://www.ptcruiserxxxx.org/galleri...4/47003thm.jpg
replace the xxxx with club & maybe you can see it
  #13 (permalink)
Old 17 Sep 2004, 02:16 am
crazie.eddie crazie.eddie is offline
Send a message via AIM to crazie.eddie
Where did you get it?
I'm surprised nobody has found a way to mod it so a line runs into the oil filler tube.
<b>\'04 PT GT Graphite Metalic w/Autostick: </b> Stage1, BTG Strut Tower Brace, Eibach Anti-Sway Bars, Airaid CAI, Mopar 2.5\" Dual Cat-Back (D: 14.48@93 - A/S: 14.56@90) <i>...more mods at CarDomain or PTCruiserWorld</i>
  #14 (permalink)
Old 17 Sep 2004, 02:26 am
A hardware store that sells compressors & comprssor parts. Look up compressors in the yellow pages.
  #15 (permalink)
Old 17 Sep 2004, 03:26 am
Mean Green Mean Green is offline
There's a couple of pics on this page
http://ptenthusiasts.org/PTForums/sh...ht=oil+ catch
\'05 Stone White SRT4
\'04 Graphite PT Automatic
  #16 (permalink)
Old 01 Oct 2004, 01:40 pm
I know where to place a catch can by the airbox. If I understand correctly, I will need to place a catch can here (see picture below) as well?
Did I correctly show the flow of the air with the red arrow?
Taikuchin, do you have a manufacturer and model number of the one you use? I tried calling a few compressor places and they had no idea what I was talking about.
  #17 (permalink)
Old 01 Oct 2004, 09:31 pm
Eddie, the picture you show with the red arrow is correct on both counts: 1 - the arrow is pointing in the correct flow direction, 2 - you do indeed want a catch can there.
In fact, that is the ONLY place you want a catch can! As I said before, the line on the driver's side that normally connects to the stock airbox is primarily an air make up line and needs to be able to draw air INTO the cylinder head function properly. If you connect it to a CAI you will deny this line it's abiltiy to draw air in - Bernouli's Principle will take over, and the air volume flowing through the CAI will actually begin pulling air from that line as well.....the opposite of what you want. The only time that line expels air is when the car is under boost. This is another reason why the AirRaid intake is such a good setup.
The line in the pic you point to, Eddie, is always flowing from the cylinder head to the intake manifold, and a larger volume of oil moves through this line than through the other. There is actually a valve on this side (the PCV valve - positive crankcase ventilation) which prevents air from coming in. Splice your catch can into this line, which is what I did, even though the can itself is behind the battery. I now have a simple breather element on the driver's side line and will post a pic or two over the weekend showing this.
  #18 (permalink)
Old 01 Oct 2004, 09:59 pm
Thanks. I just wanted to clarify. I couldn't fine the fuel filter that looks like this. I went to Autozone & Pep Boys, even Sears & Home Depot under the compressor equipment. I did find something similar, but they were large white plastic fuel filters. They were cheap, but I didn't like the look of them, especially in my engine bay. There was this one I saw at Autozone. I was contemplating on buying, but I figured it may not be large enough to hold the oil. I held of from buying it and figure I would do more research. It was nice, since all I had to do was cut into hose from the PCV to the intake manifold and insert it inbetween. But like I said, it may not hold enough of the oil. Worse comes to worse, I could just empty it weekly.
The nice thing is, there are some shiny parts, and the fittings comes in various sizes (1/4, 5/16, & 3/8). I'm concerned that the fitting for the hose is made of plastic. Will the plastic be safe?
After looking at this page even more, there is this one that looks like a chrome fitting. The only thing I need to know is what size the hose is. Does anybody know what size the hose is from the PCV to the manifold?
  #19 (permalink)
Old 02 Oct 2004, 01:11 am
The couple of filters you linked to aren't really what you want. Those are fuel filters and are designed to remove solids from a liquid and pass the liquid through. The filter shown in the $20 catch can website is designed to filter solids AND liquids from air, which is what we want to accomplish.
I found this link http://www.houseoftools.com/product.htm?pid=15005 but the filter is a little pricier than $20. I haven't gone to my local PepBoys, AutoZone, Kragen, etc yet, but I may over the weekend just to see if I can find the right parts.
Strange thing is I couldn't find anything for the Amflo 3001 pictured on the $20 catch can site.
[/b]EDIT:[b]Well now, how's this for luck? I just found these three items on ebay, but the last two may have fittings that are too large although I'm not really sure on that.
http://cgi.ebay.com/ws/eBayISAPI.dll...3063 190&rd=1
http://cgi.ebay.com/ws/eBayISAPI.dll...2989 720&rd=1
http://cgi.ebay.com/ws/eBayISAPI.dll...2989 337&rd=1
  #20 (permalink)
Old 02 Oct 2004, 05:26 am
Thanks, you've been alot of help. With your help, I found this SRT Forum that listed the following...
quote:$20 Oil Catch Can
Max flo mini air filter found at home depot
1: Campbell Hausfeld mini air filter (MP5138)
2: Solid Brass Male Barbs (BC3207)
5- Feet of 3/8 Fuel/Vacum Hose
OR
Amflo mini air filter
1: Amflo Mini Air Filter (3000-RET)
2: Solid Brass Male Barbs (406-RET)
The Amflos are hard to find, but I did find a site that sells the MP5138.
FYI, here's a detailed diagram on the catch can setup for those interested.
vB code is On
Update on Flow Back Catch Can littleblueGT Turbo Performance 3 12 Sep 2006 09:29 pm
FLOW BACK CATCH CAN littleblueGT Turbo Performance 4 03 Sep 2006 02:18 pm
What to do with oil collected in Oil Catch can? crazie.eddie General PT Cruiser Discussions 1 25 Oct 2004 09:20 am
Greddy Catch Can crazie.eddie Tech & Performance Forum 10 20 Oct 2004 03:00 am
Catch Can Really Works! Mean Green Turbo Performance 24 02 Mar 2004 02:56 pm
Archive: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45
  Equity Release | Personal Loan | Debt Help | Free Advertising | MPAA
