P 1684 & P 0455 Codes
Old 20 Sep 2004, 09:06 pm
Default P 1684 & P 0455 Codes
Any help and/or advice would be greatly appreciated. My check engine light came on and I found out through here how to get the codes, but I do not know what they mean. It rained here quite a bit the other day and I crossed a few deep water spots and maybe that caused something? I checked the gascap also and it is on tight. Thanks.
Old 20 Sep 2004, 09:24 pm
gonzomania's Avatar
Send a message via AIM to gonzomania
Opiate,
P1684 is the code for The battery has been disconnected within the last 50 starts.
P0455 a large leak has been detected in the evaporation system.
Hope this helps
Old 20 Sep 2004, 09:36 pm
Hmmm, Not really. I have never disconnected the battery since I have owned it (3 months) and a large leak in the evaporation system?? What does that mean?
Old 20 Sep 2004, 10:55 pm
gonzomania's Avatar
Not sure , I just gave you what the codes meant. Sorry
Old 21 Sep 2004, 10:27 am
P1684 USED to mean the battery was disconnected. For the last few years, it's changed to a system readiness code. Not all of the drive cycles have passed, so the 1684 code will show up.
I've posted this about 1000 times on 8 forums over 4 years, but old data is hard to get updated.
P0455 is either a gross malfunction in the EVAP system, or you left the gas cap loose or refuelled without turning the ignition off while the EVAP self-test was running.
Old 21 Sep 2004, 11:10 am
gonzomania's Avatar
MX-5,
Sorry I took out a list I had printed up from the Chrysler site along time ago.
Old 21 Sep 2004, 07:03 pm
No problem Gonzo,
It's just that the old info is still floating around the 'net with no corporate supervision.
Check engine light, ever hear of these codes? MINIHEMI46 Turbo Performance 15 09 Mar 2010 08:58 pm
Check Problem Codes Yourself! turbomangt General PT Cruiser Discussions 13 23 Feb 2006 06:27 am
Fixing codes yourself Opiate General PT Cruiser Discussions 4 29 Oct 2004 08:00 am
