Rack and pinion vs?
Old 05 Oct 2004, 10:06 pm
Send a message via AIM to jmack
Default Rack and pinion vs?
Ok, finally took the car in today to have the rack and pinion replaced. My loaner car gave me quite a scare. It was a 2002 Dodge Stratus. I immediately noticed something different when I was driving but couldn't figure it out. It drove "funny." Then when I got on the interstate I could really tell the difference. I barely move the wheel and the car would almost swerve off the road!
SO my question is this: what is the difference between rack and pinion and "the other steering"?
Old 06 Oct 2004, 03:35 am
Send a message via AIM to crazie.eddie
I got curious too and found this site.
<b>\'04 PT GT Graphite Metalic w/Autostick: </b> Stage1, BTG Strut Tower Brace, Eibach Anti-Sway Bars, Airaid CAI, Mopar 2.5\" Dual Cat-Back (D: 14.48@93 - A/S: 14.56@90) <i>...more mods at CarDomain or PTCruiserWorld</i>
Old 06 Oct 2004, 08:07 am
There's also worm and roller - rack and pinion is supposed to be the best - least "slop".
Old 06 Oct 2004, 10:41 am
jmack,
Both the PT and Stratus are Rack & Pinion steering, you should not have felt that much difference between the two. The ratio may be a little different between the two, that's all.
John & Terry
"His" - 2002 Inferno Red Touring Edition
"Hers" - 2003 Electric Blue Limited Edition
Del Val PT Cruisers
Old 06 Oct 2004, 03:31 pm
Oh it was quite different. Maybe since my rack and pinion was damaged, i couldn't really tell the difference. Nonetheless, they called this morning. they were like "Mr Mcdaniel, it seems we also will be needing to change the Axle Boots." I was like "um no. I have already had to squeeze the 700 dollars to fix this so No, you will not be doing that today."
About to start work on modding my car and making it look even better than it already is!
Old 06 Oct 2004, 08:29 pm
If the boots have a hole in them (torn or punctured) it will allow water, dust & dirt to enter and ruin the CV joint, then you WILL have a real problem($$$'s). I suggest you take it to a garage or have someone inspect them to see if they ARE damaged. Or have the dealer show you the damaged boot. Somehow it dosen't seem that both of them would need to be replaced at the same time.
Old 06 Oct 2004, 08:37 pm
Well it is funny you mentioned that. My father and I actually looked at both of them just less than a month ago. They are fine, Hooligan. I just want my car back before they decide it needs 24K plated plugs or some other crap.
Crazie Eddie, that was a great site. I had forgotten about that wonderful site.
They called today. I get to go in the morning to pick it up. I am so glad to be getting that car back!
Rack & Pinion Rockdiggety Tech & Performance Forum 3 19 Oct 2005 10:49 pm
Steering/Popping/Confusion jmack General PT Cruiser Discussions 13 17 Jun 2004 01:35 pm
My backordered Rack & Pinion & PCM are in TripleJackInGA General Turbo Discussions 1 14 Oct 2003 11:04 pm
Replaced under Warranty - PCM and Rack & Pinion skylight General Turbo Discussions 5 19 Sep 2003 02:33 pm
steering problem-- Michael Day!!! nbr10 Tech & Performance Forum 10 08 Jul 2003 01:33 am
