PT Cruiser Forum Car Videos
Jeep Parts | Car Rims
Floor Jack Points on PT
Old 15 Oct 2004, 04:41 pm
rszappa1 rszappa1 is offline
Default Floor Jack Points on PT
I know the points that Chrysler says for hoisting the Pt...Ther is a diagram inside the passenger side door. But looking at the four areas they reccomend it seems that the flat area metal is very thin. when you tap it with your fingers there does not seem to be any reenforced metal just this sheet metal...also no rubber pad for it...like my caravan has. I dont want to damage the PT with a floor jack. Can you please tell me where you are lifing your PT at. I do have the Rhino Ramps but I need to rotate the tires so I have to lift it off the ground. Thanks for all of your help....
Old 15 Oct 2004, 05:20 pm
CREWZIN CREWZIN is offline
Just looked under mine. The points where they tell you to use the jack are double layers and can take the floor jack without a problem. I used floor jacks over 20 times (every 3,000 miles for oil changes) and there's no damage done to the jacking points.
Old 15 Oct 2004, 05:48 pm
Jimbo Jimbo is offline
Just rotated tires on wifes car.Look for the little triangles.
behind the front tires it's a ways under there. On the back
it's right in front of the rear tire. You will see a little triangle.
Hope this helps.Just a thought rotate front to rear,don't
criss cross. If you have the bad for a years.They don't like to
be criss crossed.Hope this makes sence.
04 cool vanila Limited Turbo
Wife has a 03 limited
(Steel Blue)
Old 15 Oct 2004, 10:42 pm
tpscruiser tpscruiser is offline
Like Jimbo said, the front points are a ways in. I put a piece of red reflective tape at each triangle/jacking point so they would be easy to find should I need to do an emergency tire change on the highway.
[8)]
John & Terry
"His" - 2002 Inferno Red Touring Edition
"Hers" - 2003 Electric Blue Limited Edition
Del Val PT Cruisers
Old 16 Oct 2004, 10:56 am
Thanks for your help...by the way i have hydro edge tires on it so all i can do is rotate front to back...when you use the floor jack are you using any flat piece of wood or rubber on the lift point on the jack . My jack is not smooth and flat it is round with three lifted areas on it.
Old 16 Oct 2004, 11:04 am
I have the same type of jack, I didn't use any wood or
rubber,but it's a good idea though.I had no problems without
it.
(Steel Blue)
Old 16 Oct 2004, 03:03 pm
gonzomania's Avatar
gonzomania gonzomania is offline
Send a message via AIM to gonzomania
Jimbo,
I crawled under my car and saw the little triangle cut outs. The front one you mention is about 1 foot to the middle of the car, behind the front wheel. I looked on my CD and it shows the flat spot under the rocker panel and metal does seem very thin but it must be reinforced. I tried to copy the diagram and paste, but with no luck.I'd like to be in the correct spot doesn't seem the correct place to then put jack stands?
Gonz
Old 17 Oct 2004, 07:09 pm
quote:Originally posted by gonzomania
Jimbo,
Gonz, I got that from my owners manuel, seems weird to me also
because it's way under there,but it seems to work.
(Steel Blue)
Old 18 Oct 2004, 07:58 am
I cut a piece of inner tube and put that over jack head - has held up well. Probably doesn't matter.
vB code is On
insurance on your points Punch Non-PT Discussions 6 03 Dec 2003 07:23 pm
Lube Points? MCM Tech & Performance Forum 1 19 Nov 2003 02:04 pm
BEST RPM SHIFT POINTS MEXICANPT Turbo Performance 8 08 Sep 2003 07:57 pm
  Debt Consolidation Loans | Virtual pets | Flights | Consolidate Debt | Epson Stylus Photo Printer
