no heat at feet ?? why??
Old 19 Oct 2004, 06:12 pm
Default no heat at feet ?? why??
hello all, my wifes 04 touring pt has no heat at the feet, all seems fine if its blowing in your face anyone know what is wrong??
Old 19 Oct 2004, 06:31 pm
Check the A/C vent knob to see if it is set to the correct setting that would direct the air to the floor area. If that doesn't solve the problem suggest you take the car into the dealer as it should be covered under warranty. Good luck.
Old 19 Oct 2004, 08:13 pm
Send a message via AIM to sakigt
You have your shoes on.
Ha. Kidding. Actually I know when I really want my tootsies warm I have to stick my foot waaay up above the pedals to feel anything. Are you saying its not on at all? If so, sounds like a dealer problem.
14.67 @ 94.5 <--- Self Proclaimed Fastest East Coast PT with Black wheels!!!
Old 19 Oct 2004, 08:33 pm
wife says heat is fine, then turn it like you want heat to come out down the bottom and no heat??
Old 19 Oct 2004, 08:39 pm
Bob, do you feel any resistance when you turn the selector knob? If not, maybe the cable popped off. Dealer should be able to fix it quickly.
John & Terry
"His" - 2002 Inferno Red Touring Edition
"Hers" - 2003 Electric Blue Limited Edition
Del Val PT Cruisers
Old 19 Oct 2004, 08:59 pm
Dealer, dealer and dealer!!!! Especially with it being brand new '04.
Old 20 Oct 2004, 08:32 am
Also possible a hose popped off or a vacuum hose popped off - flap is vacuum controlled, I believe).
In any case, if you've set it right, and no heat, go to dealer.
Old 20 Oct 2004, 09:40 am
Don,
The “re-circulate” & “Fresh air” modes are controlled by vacuum, the air flow directions are controlled by a cable.
John & Terry
Del Val PT Cruisers
Old 23 Oct 2004, 05:10 pm
now its working!![:I] mabye it was stuck??
No Heat dsouder General PT Cruiser Discussions 10 03 Nov 2011 10:42 am
Rough Idle with Heat on Carchrism5 Tech & Performance Forum 2 05 Dec 2005 11:14 am
heat and fan control ~ what to expect on 1 and 2 ? frances General PT Cruiser Discussions 7 22 Dec 2004 09:09 am
heat GTCOOL Stage Turbo Kits 12 13 Jun 2004 05:59 pm
Arizona heat Geeksterman Turbo Performance 4 29 May 2003 07:08 pm
