I checked my tire pressure today, and all of em are right at 31 psi. What is the best setting for low profile tires(if that makes a difference) for optimal gas mileage?
It should be on the driver's side door. I believe it's at 38 psi.
![]() <b>\'04 PT GT Graphite Metalic w/Autostick: </b> Stage1, BTG Strut Tower Brace, Eibach Anti-Sway Bars, Airaid CAI, Mopar 2.5\" Dual Cat-Back (D: 14.48@93 - A/S: 14.56@90) <i>...more mods at CarDomain or PTCruiserWorld</i> |
The GT's with the 17" wheels are recommended by Chrysler to run 38 psi cold. The 15 and 16" wheels are recommended by Chrysler to run at a lower pressure (32 psi probably).
With most tires, increasing the tire pressure by 2-3 psi over factory recommendation when cold will slightly decrease rolling resistance with a corresponding decrease in ride comfort. The tendency of most folks is to ignore tire pressure. Therefore, most cars tend to have under-inflated tires. Grossly over-inflated tires will decrease traction due to reduced tire contact area, accelerate wear toward the center of the tire and reduce handling in inclement weather. Grossly under-inflated tires will accelerate wear on the outside edges of the tires, over heat causing premature failure and potentially, roll off the rims during emergency handling maneuvers. If you are running the stock rims and tire, use the recommended factory pressures + 2 or 3 pounds if increased fuel economy is your objective. If your rims or tire are not stock, many other factors come into play.
2003 Almond GT AutoStick, body colored rear splash guards and hood struts, chrome gear shift, AC & vent knobs, billet steering wheel spokes and pedals, AMX1397 Turbo-Intake Pipe. |
TM,
being that you dont have the factory wheels and tires i would say the best bet is to look at the side of the tire. Inflating to the max pressure will give you crisp handling and improved fuel mileage at the expense of a slightly firmer ride. On my factory 16's i used to run 42psi my 17's get 38psi the 18s are @ 40 too much and you'll wear the center cause it will baloon too little and the tires will roll over on turns and youll see more wear on the outer parts of the tire. be sure to inflate and check pressure first thing in the morning before the car is driven, as tires heat up the pressure increases and you will get incorrect readings .
www.cardomain.com/id/rallydrock |
pep boys have a valve cap that reads the air pressure all the time just look at the end of the cover it tells the tire pressure. I think their $7.99 a pack of 4. They also have several different pressure settings you can buy.
![]() flames&stripes by \"gator\" 2003 milan dragway \"chrysler classic\" winner |
Alright, thanks guys. Now I have a reason for my bad gas mileage
2001 limited edition midnight blue PT, 17\" enkei wheels, rear spoiler,silencers removed, k&n drop in filter,MX-5\'s 1-2 burp-free shift mod, 1 10\" subwoofer, and a Dynomax muffler. (Just a 17 year old who loves his car)
KingKole02 ![]() SW Florida PT Cruisers Secretary/Treasurer/Webmaster www.swfloridaptcruisers.com Just Cruisin, 03 N/A auto. TE Steel Blue w/ pearl coat & chrome package. Too many extras to list, see pics For my story and cruiser pics go to: www.kingkole02.com Other pages I have: http://www.ptcruiserweekly.com |
| Error Codes | thegoldpt | Turbo Performance | 6 | 07 Apr 2007 02:26 pm |
| Tire Accu-Pressure Safetly Cap Warning | Curruzr | General PT Cruiser Discussions | 6 | 22 Aug 2005 07:46 am |
| Tire pressure recommendations | OurPTGT | General Turbo Discussions | 11 | 14 Oct 2004 09:22 pm |
| 15" tire pressure? | Brad Vandrasik | Wheels, Tires, Suspension | 6 | 03 Dec 2003 11:22 am |
| Tire pressure | lip | General Turbo Discussions | 2 | 10 Aug 2003 06:38 pm |
