Tranny Failed then Power Steering Switch?
  #11 (permalink)
Old 15 Dec 2007, 10:57 pm
Default Re: Tranny Failed then Power Steering Switch?
Sounds like there should be no continuity between the pins when there is pressure, when no pressure there should be continuity. at least that is what im getting from the passage. if there is any question please get a second opinion from your technician.
06 Touring Edition NA/Auto. Airaid intake, Magnaflow Stainless cat-back exhaust, Taylor Thundervolt plug wires, rear lowered 1.75" with H&R Springs.
Yep, buying parts I cant afford with money I dont have to impress people I dont like anyways.
  #12 (permalink)
Old 15 Dec 2007, 10:59 pm
DJmart's Avatar
Send a message via AIM to DJmart
Makes perfect electrical sense to me!
  #13 (permalink)
Old 16 Dec 2007, 12:22 am
Originally Posted by DJmart View Post
So I am guessing, no 12v reading... bad switch.?
Well, Cartman posted "When pump pressure is low, the switch is closed." closed switch = zero volts. If you weren't turning the wheel at that time, that's normal,
But, if you say you turned wheel and RPMs dropped, then a bad switch is likely.
  #14 (permalink)
Old 16 Dec 2007, 01:07 am
I believe the switch works by completing the circuit. one wire tot he switch will be a constant hot provided byt he ECU, the other wire will be a ground. when there is no pressure, the circuit is closed or completed. when there is pressure, the switch is open, meaning the circuit is open and no flow of voltage through it.
  #15 (permalink)
Old 16 Dec 2007, 08:44 pm
When a switch is open, you'll see 12V across terminals, when it's closed, you'll see zeror. Think of a fuse - if you see 12V across a fuse, it's blown (open)
  #16 (permalink)
Old 16 Dec 2007, 10:15 pm
youll see 12 volts across the terminals reguardless of the switch position due tot he fact that your tester will be completing the circuit, not the switch. the only true way to test the switch is a continuity test. if you must test for voltage, then you place the neg(-) side of your DVOM on your neg(-) batt terminal, and the pos(+) side of your DVOM to the ground terminal of the switch. when the switch is engaged, you will have a 12v signal coming from it.
As a side note, NEVER use a test light when diagnosing new vehicles. damage tot he computer will result! ECUs dont use full 12V as signals, and most signals are extremely low amperages. using test lights may inadvertantly send full batt voltage tot he ECU and fry it. Not to mention if you accidentally get into an airbag harness.....BANG!
  #17 (permalink)
Old 17 Dec 2007, 09:10 am
DJmart's Avatar
Well i was unable to test the switch, the wires were soooo close together, and I did not have a ton of time to test. I needed a "thinner" probe to be able to get into the small connector.
For response to above, I never use a test light, nor do I have one. But I did try to use the continuity feature on the multimeter.
As for the check engine light, It has not come back on yet!! I will keep all posted. Maybe the power steering fluid has finally circulated through the lines.
I was reading in a shop manual for trouble codes, and it says you must go over 50MPH for 30 seconds before the light would show, if indeed the switch is no good... I did that yesterday, and no problem! and it was much longer than 30 seconds, highway!
Well, Ill keep you all posted
-DJ
  #18 (permalink)
Old 17 Dec 2007, 10:21 pm
yeah, its a pain sometimes. if you do a lot of diagnostics you might thinking about investing in thinner probes, you can pick them up online or on tooltrucks. comes in wicked handy for backprobing small connectors.
  #19 (permalink)
Old 18 Dec 2007, 07:02 am
DJmart's Avatar
I should just buy my self a nice one....
The one i have does not have detachable probes.... *sigh*
Still no light!
  #20 (permalink)
Old 18 Dec 2007, 11:09 pm
i guess no news is good news eh?
Power steering whine problem identified sawdust123 General Turbo Discussions 5 10 Dec 2008 07:24 pm
Yet another Power Steering problem fritz_t_coyote Tech & Performance Forum 3 23 Nov 2005 04:28 pm
ATF + 4 or 5 for power steering? quicksilverdon General PT Cruiser Discussions 2 21 Feb 2005 05:00 pm
I think I'm having a power steering problem! lumofny Tech & Performance Forum 5 18 Jan 2005 01:12 pm
Power steering leak . . . gonzowing Tech & Performance Forum 5 15 Apr 2004 10:28 pm
