Rear window washer
Old 10 Nov 2004, 12:44 pm
Default Rear window washer
Had to use the RW washer the other day, and it seems like it's just "blubbering" out. I get this 1" wide, flat stream that just flows out and down the window. It seems like it should come out in some sort of spray when used.
PTSleeper
Old 10 Nov 2004, 01:42 pm
First check to make sure your fluid reservoir is full, while you're there check to make sure the pick up is clean and free of any debris. If all that is favorable, take a straight pin and clean out the oriface at the discharge point above the rear window, sometimes wax can clog the opening. Hope this helps.
Old 10 Nov 2004, 06:41 pm
Does that mean it's suppose to spray and not flow?
04 Inferno Red GT w/Autostick. Bone Stock for now.
Old 10 Nov 2004, 07:28 pm
Yes, it should squirt
Old 10 Nov 2004, 08:15 pm
Mine don't squirt, it just "blubbers" out like Sleepers!!! [:0]
PTurbed
Old 10 Nov 2004, 08:59 pm
Took my rear wiper off and put on a handle./Every rear wiper I've ever had worked like crap
04 cool vanila Limited Turbo
Wife has a 03 limited
(Steel Blue)
Old 10 Nov 2004, 09:36 pm
Mine comes out like a horse pee'n on a flat rock.
Old 10 Nov 2004, 10:41 pm
Cal Cruzer... Nice visual... eeewwwwww
Current Mods: Removing small pieces of paint on the hood and grille by painstakingly driving into flying debris kicked up by preceeding vehicles
Old 11 Nov 2004, 12:02 am
Let the washer spray for a while. The pump in in the tank by the windshield and if you don't use the rear one often, there may be air in the line and needs time get through.
John & Terry
"His" - 2002 Inferno Red Touring Edition
"Hers" - 2003 Electric Blue Limited Edition
Del Val PT Cruisers
Old 11 Nov 2004, 11:57 am
I, too, replaced the rear wiper with a billet nostalgic handle, since I never used it. Now I'd like to convert the rear window wiper/washer switch to use with an intercooler sprayer. Might as well get some use out of that extra dash switch!
Tom \"Terrific\" Myers
2004 DC3 - \"Dreamweaver\"
Phoenix, AZ
http://www.cardomain.com/memberpage/578198
http://www.ptcruiserworld.com/DreamWeaver/
Oval Rear Window judpma Exterior Accessories Forum 4 19 Jul 2005 09:19 am
Broken rear quarter window! littledog General PT Cruiser Discussions 12 20 Jan 2005 09:20 pm
R&R the rear window glass? Cal Cruzer General PT Cruiser Discussions 3 18 Nov 2004 12:26 am
Leaky rear window washer Jimbo General PT Cruiser Discussions 2 02 May 2004 09:33 am
Split Rear Window Kit sctvguy Exterior Accessories Forum 3 23 Oct 2003 01:01 pm
