TURN SIGNAL DISPLAY
Old 10 Nov 2004, 11:42 pm
KIMS CRUZER's Avatar
Default TURN SIGNAL DISPLAY
Let me try to explain my problem.[] When I put my turn signal on to turn right, the display doesnt blink on the panel. My front fog lights also come on. Which causes the bright lights display to light up. If I do not turn the signal all the way off , fog lamps stay on.Is it a fuse, wiring problem? HELP![:0]
Old 11 Nov 2004, 12:08 am
Sounds like a bad multi-function switch. There have been other reports of fog lights turning on with the turn signals.
John & Terry
"His" - 2002 Inferno Red Touring Edition
"Hers" - 2003 Electric Blue Limited Edition
Del Val PT Cruisers
Old 11 Nov 2004, 02:47 am
Send a message via AIM to bigtommy83
Yep...gotta be the multifunction switch. It's not an unheard of thing. Just like Liberties and Sebrings.
\'04 GT 5-speed, Brand X, Air Force One Intake, Custom Flowmaster Exhaust (retired), SRT-4 exhaust no resonators, AGP Wastegate, Crusher Kit, Former Chrome Package, Mopar BOV, Custom Sub Box, Mopar Pillar Gauges, Hood Scoop, MBC, Stage 1, Mopar Stage 1 Springs, Hurst STS
Future Plans: Custom Intercooler Sprayer, 2-tone Paint Job
\"Hondas are like cigarettes, everyone cool smokes them\"
Old 11 Nov 2004, 10:56 am
Yup, agree. Not hard to replace - phillips and Torkx screws and clips in - if you're out of warranty.
Old 11 Nov 2004, 03:01 pm
Where is the multi-function switch located. I will have to do it myself. My PT is out of warranty.Thanks a bunch to my PT buds for the info![?][^]
Old 11 Nov 2004, 03:46 pm
Kim,
The switch is right there at the end of the turn signal lever in the steering column. You will need to remove the covers, 2 phillips head screws just behind the steering wheel and the top and bottom snap apart. I think the switch requires a T20 Torx driver to remove those screws. Just remember to order the correct switch, the switch is different if you have factory fog lights.
Goog luck!
John & Terry
Del Val PT Cruisers
Old 11 Nov 2004, 05:17 pm
gonzomania's Avatar
Send a message via AIM to gonzomania
Kim,
I had a similiar problem about 8 mths ago. This is worth a try. Check your ground cable near your battery, it is grounded to the chasis. It may have loosened or is making poor contact. May need to be cleaned and tightened. Other thing I think my problem was, I drove threw a puddle and I think the foglight bulb socket may have gotten corroded. Try some dielectric grease on the base of the bulb and reinstall (don't touch the glass). Hey its worth a try it's pretty much free compared to a multifuction switch.
Gonz
Old 11 Nov 2004, 09:08 pm
[quote]Originally posted by tpscruiser
Battery disconnect needed???[:I]
PTurbed
Turn Signal jmack General PT Cruiser Discussions 5 12 Apr 2005 11:57 am
Turn Signal Fuse Problem Indynick General PT Cruiser Discussions 1 04 Jul 2004 07:33 pm
blue turn signal bulbs that turn orange when in us Capt Kidd General PT Cruiser Discussions 1 04 Jun 2004 10:10 pm
Turn signal & stop light gonzomania General PT Cruiser Discussions 12 25 Apr 2004 01:18 pm
Turn signal gonzomania Exterior Accessories Forum 12 30 Mar 2004 08:53 am
