PT Cruiser Forum Car Videos
Car Rims
Removing intake manifold
Old 20 Nov 2004, 09:08 pm
1wedwudy 1wedwudy is offline
Default Removing intake manifold
Thinking about removing the intake manifold and painting it. How difficult is it to remove. Anything I need to watch out for?
Old 20 Nov 2004, 10:22 pm
Grouch Grouch is offline
This should help.
http://www.imagestation.com/album/?id=4291473219
Greg Gavencky
The New Jersey Cruisers
www.njcruisers.com
Old 21 Nov 2004, 01:30 am
thanks pal
Old 22 Nov 2004, 08:55 am
Yeah - hang onto the bolts when you take them out - I had one fall down behind the grill in front of the radiator. Could see it but was hard to get to.[xx(]
Old 22 Nov 2004, 08:24 pm
Hooligan Hooligan is offline
If you have an extenable magnet, it makes it much easier. I got one at Big Lots for a buck, sure has saved my butt a few times.
Old 24 Nov 2004, 05:58 pm
trieber trieber is offline
Speaking of working on the intake. I was changing my spark plugs and couldn't get the wires off the throttle body like I should have, so I just spun the intake manifold out of the way and everthing was cool. When I was putting it back to gether, I noticed that the center spacer for the intake bolts was missing. It had fallen out when I put the spin on it. I never did find it after a CSI investigation in my intake and all over the front of the car. I just tightened that bolt down as much as I could before it started to pull into the plastic of the intake manifold. Been working well since then.
Old 22 Sep 2007, 09:51 am
Kevin B Kevin B is offline
Default Re: Removing intake manifold
The image station link no longer has the images. Can anyone tell me if the seals for the intake are O-rings? Do they need replaced? All my AutoZone could do was order a complete intake kit upper and lower gasket kit. Is that what I need just to remove the upper intake when I want to change the plugs? Thanks for any help. I have a Hayne's manual just need to know if I need gaskets/seals before I open my '03 non-turbo up.
Kevin
Old 22 Sep 2007, 10:24 am
Kevin, the gaskets can be reused. Just be very careful when you lift the manifold. There should be 4 red/orange gaskets pressed into grooves, make sure they are seated when you reassemble. Manifold bolts should be torqued to 105 inch lbs in this pattern 5, 3, 1, 2, 4. I usually snug the bolts, then take them part way with the torque wrench and then torque to the final.
Plugs to be torqued to 13 foot lbs after applying anti seize to the threads and dielectric grease on the boots.
2008 Silver Steel Metallic, Touring, NA, Sirius; chromed door handles; lower grille; fog light surrounds; chrome front & rear bumpers strips; Airaid air filter; Bassani duals; Modesty cover; Autolite AP5263 Platinum Plugs (.040); Crane Plug Wires; NAPA Ceramic pads; Blane hood struts; PTeazer Gas, Brake & Foot rest Pedals.
Old 22 Sep 2007, 10:30 am
Thanks. Are the seals O-rings?
Kevin
Old 22 Sep 2007, 12:55 pm
I guess you could call them "O" Rings, they are round diameter, but fit into a somewhat oval groove in the intake.
vB code is On
Turbo Intake Manifold mvandale Classifieds: For Sale/Trade 0 19 Jan 2006 10:18 pm
Torque question for intake manifold on a GT crazie.eddie Tech & Performance Forum 5 29 Oct 2004 04:00 am
Removing intake manifold irelandmoss General PT Cruiser Discussions 1 08 May 2004 10:00 am
polished intake manifold(( IT"S HERE)) amx1397 Turbo Performance 25 07 Jan 2004 11:35 pm
Upper/lower intake manifold gasket leak? im4gzs Tech & Performance Forum 14 03 Jan 2004 01:52 am
  Free Credit Report | Bad Credit Mortgages | Personal Loans | Loans | Mortgage
