rear windows rattle
Old 04 Dec 2004, 05:16 pm
gonzomania's Avatar
Send a message via AIM to gonzomania
Default rear windows rattle
Does anyone elses rear windows rattle if the window is down 2 to 4''from the top. I really never drove with those windows cracked, my daughter did it today and it was rattling around. Any help would be appreciated[:I]
Old 04 Dec 2004, 06:35 pm
My rear windows don't rattle when they are down 2-4" but my front windows have ever since I changed to M-3 type mirrors.
Old 05 Dec 2004, 05:57 pm
with the windows in certain positions there is severe buffeting
sounds like a helicopter right over the car. got so bad i thought it was going to either pop my ears or my back window. if you have a sunroof you will notice that with the auto-open function it does not open all the way. this is because of poor design, if you were to open the sunroof all the way and go about 40-45 you will be amazed at the buffeting.
anyway the windows do move it is only rubber holding them even if it is closed and you push on it it will move.
Old 05 Dec 2004, 06:51 pm
My 2001 PT's sunroof opened all the way. One button press opened it like the current one's do, and second press opened it all the way. The buffeting was bad, but if I cracked open the driver side window a alittle bit, it all went away. It's because of the shape of the car, and design of the interior cabin.
Old 06 Dec 2004, 12:50 am
I was assuming that Gonzo was referring to a rattle rather than buffeting. Buffeting is a MAJOR problem in PT's. Open any one window and your ear drums will be in danger. Open a second window and 90% of the problem will go away.
As far as the rattle in the rear windows, if it is a rattle rather than buffeting, that is not normal.
Old 06 Dec 2004, 10:16 am
i went off on a buffeting tangent there, was just thinking that the windows may have been moved back and forth by the air pressure causing a rattling sound.
Old 06 Dec 2004, 03:03 pm
Mine make what could be interpreted as a rattle in that position. It is not buffetting as it does it even at low speed as I drive though my neigborhood and hit the cobblestone strips that serve as speed bumps. I found that it was more that the glass was "ticking" in the window rails. I spayed some dry lube silicon spray on the track and it solved the problem. Unfortunately the sound returned several months later. I guess this will have to be a normal maintenance item for me in the future.
Ton of parts for sale, check list, make offer. ptcruzin42 Classifieds: For Sale/Trade 10 20 Sep 2004 11:50 pm
The Rear Brake rattle that drives me Nuts - Help! Sime Tech & Performance Forum 16 29 Apr 2004 12:40 pm
Rear seat belt rattle turbomangt General PT Cruiser Discussions 0 06 Oct 2003 09:57 am
Can the rear windows go all the way down? OVcruzn Interior Accessories Forum 4 30 Jun 2003 07:39 pm
Rattle in rear interior compartment! gtobey General PT Cruiser Discussions 6 30 Oct 2002 10:10 am
