On the wife's Cruiser malfunction light came on and stayed, it's
mot blinking.Looked in book said it could be bad gas or loose gas cap. Or something like that.I did error code deal,I think I did it right. It came up P 1604, what does that mean? |
Jimbo,
Don't think this will help much but.... Additional Diagnostic Trouble Code Ranges Other DTC ranges are defined for either manufacturer specific codes or under the control of SAE (Society of Automotive Engineers) and not yet defined. This section documents these additional ranges. Refer to your vehicleÂ’s repair manual for manufacturer specific Diagnostic Trouble Codes. P09XX Transmission P1XXX Manufacturer Controlled P10XX Fuel and Air Metering and Auxiliary Emission Controls P11XX Fuel and Air Metering P12XX Fuel and Air Metering P13XX Ignition System or Misfire P14XX Auxiliary Emission Controls P15XX Vehicle Speed, Idle Control, and Auxiliary Inputs P16XX Computer and Auxiliary Outputs
took it to dealer, He said if it's still on Thursday make an apointment. Went to get back in car and started it ,the light
was out.So I guess all is well.
04 cool vanila Limited Turbo ![]() Wife has a 03 limited (Steel Blue) |
The sevice department probably just took the bulb out[:I]
Just kidding Jimbo. I'm sure the problem was taken care of, sounds like you have a decent dealer.
P1604 is "PCM internal dual-port RAM read/write integrity failure". The test checks for power to the PCM with key on. If the power supply is okay, you replace the PCM, period. [:O] Sounds like you have an intermittent power problem or the PCM is dying internally. You could check connections, but this should be covered under warranty.
2004 Dark Plum Base with windows tinted, cabin filter, silencers removed, fog lights, 18\'s, all Red taillights, Blaine\'s struts, modesty cover, color-matched center dash, 06 rear bumper |
right now it's ok and they won't fix anything that's OK. Thanks for the heads up on the code.
Depending on your relationship with the dealer, they may just replace the PCM. The code will stay in history for a while (50 starts), so they can 'pull' it. If you say "Will you cover the tow when it dies?" they may be more willing to fix it before you get stranded, especially if there are any recalls that have not been done to your car. Call with your VIN and a decent attitude.
Hypergrounding will fix it! [:I] Draws off all the bad Karma and puts Bling-Bling back into the putz! [8]
Also could be time to trade....see above.
Inferno Red \'04 GT Autostick, Stage I, BTG exhaust, Airforce One intake, V.A.K. Candy Red upper charge pipe, BTG strut bar,Hyperground, chrome side spears and grill accents.
| Error Codes | skylight | Tech & Performance Forum | 7 | 28 Apr 2011 03:34 pm |
| Error Codes | thegoldpt | Turbo Performance | 6 | 07 Apr 2007 02:26 pm |
| Error Code List | skylight | General Turbo Discussions | 6 | 07 Apr 2007 02:11 pm |
| Tranny She is a no-good! | scottscars | Stage Turbo Kits | 15 | 16 Oct 2004 11:11 am |
| Torque Converter Clutch Circuit Malfunction | Marc Lublin | General PT Cruiser Discussions | 1 | 21 Jul 2004 12:53 pm |
