Fog lights won't turn on
Old 13 Dec 2004, 01:09 pm
Default Fog lights won't turn on
And it's not only the fog lights but the fog light indicator in the dashboard. That's also not working.
I called my dealer and they told me they'd look at it but they warned me that light bulbs are only covered during the first year or 12K miles. Mine has 14K. They said that was specified in the owner's manual.
Is that true or are they full of crap?
Old 13 Dec 2004, 01:50 pm
gonzomania's Avatar
Send a message via AIM to gonzomania
They are correct. Try another bulb but if the indicator on the dash isn't working sounds like a multifunction switch. Alittle pricey for the part but a snap to install a new one.
Gonz
Old 13 Dec 2004, 03:43 pm
Check the fuse first.
Old 13 Dec 2004, 03:57 pm
If the problem is the multifunction switch or a fuse, that should be covered under the warranty right? Or would they charge me for either of them?
Old 13 Dec 2004, 05:23 pm
Your fuse won't be covered, but the stalk surely will if your warranty is still good for milage and time. Check the fuse yourself by looking at the panel by your left knee. The Fog Light fuse is #8 and I think it's 15amp.
Old 13 Dec 2004, 06:01 pm
i almost promice you its the switch, its a common POS on the cruiser as i noticed on other forums, i think it was about $180 (canadian) for a new one, i threw it on myself, was pritty simple
Old 13 Dec 2004, 07:21 pm
I doubt it would be both bulbs - one should light. If it isn't the fuse, then it's the switch. [:I]
Old 13 Dec 2004, 10:29 pm
Mine is doing the same thing right now. I thought that maybe since mine are aftermarket dealer installed that was the problem. I see that someone else is having the same problem. Dealer wants to keep my car for the whole day to work on it. My lights sometimes come on but go out within ten minutes. Other times they don't work at all. As you said when they don't work the indicator light on the dash does not work either. If you get yours fix before me let me know what they find.
2006 PT Cruiser (NEW)
17X7 Motegi Wheels
215/45-17 Hankook Tire
Front lowered 1.5 inches, rear lowered 2.5 inches
Kenwood in dash CD/Sirius/Six Disk Changer
First of a few mods
2004 Mercury Marauder (Supercharged)
http://www.cardomain.com/id/bigslim2
http://www.cardomain.com/memberpage/484421
Old 14 Dec 2004, 02:47 am
SRG SRG is offline
Big Slim;
The fog lights of my 02 limited were sitting on, even though the switch was off, I had someone stand in front of the car and I just touched the switch a little(on the very end where the fog light switch is), and they blinked. It was the multi-function switch, and it is covered under warrenty.
I've heard and read of many PT's with this problem, one guy in our club even had the wiring harness on the column start to burn and melt. Even though the dealer told him he needed a new or used wiring harness AND a multi-function switch, he (the dealer) doesn't know what caused the wires burning.
Good luck!
SRG
Old 15 Dec 2004, 04:33 pm
quote:If you get yours fix before me let me know what they find.
I sure will.
Thanks.
Fog lights won't turn off DCruzer Tech & Performance Forum 17 16 Mar 2011 07:16 pm
LIghts, Lights, Lights King_Rob Classifieds: For Sale/Trade 4 20 May 2005 09:14 pm
TURN SIGNAL DISPLAY KIMS CRUZER General PT Cruiser Discussions 7 11 Nov 2004 09:08 pm
Turn Signals Not Working Indynick General PT Cruiser Discussions 9 15 Sep 2004 02:25 pm
Red Rear Turn lights Crash Exterior Accessories Forum 7 11 Oct 2001 04:28 am
