PT Cruiser Forum Car Videos
Custom Wheels
Interior Lights weird behavior
Old 13 Dec 2004, 02:15 pm
lcuadrado lcuadrado is offline
Default Interior Lights weird behavior
Hello everybody,
I was wondering if any of you heard something about what I'm about to say.
Last night I noticed that the dashboard wasn't working at all (lights, gages etc). Also, I notice that the beeping sound when you open the door and the interior light was not working as well. The radio and the headlights are working perfectly.
I decided to look at the user's manual and look at the interior fuses. I noticed that number #13 was the fuse that is related with the interior lightning. I decided to take it out and check if is blown. After taking it out, the fuse seems to be OK. Then I put it back on and the interior light was working. I started the car and the gages are working as well. I'm a little bit confused.
Something else that I want to add is that where I live can get quite cold. I have a 2002 Base Model PT Cruiser.
Have any of you heard about something like this?
Best regards,
Luis E.
Old 13 Dec 2004, 03:17 pm
purple04 purple04 is offline
Just to clarify, it was working poorly, then after R&I of fuse, it was okay? That's a poor connection that was fixed by the movement. I'd say it's time to 'wiggle' all the fuses and maybe even retighten all grounds. The lights and bell are controlled by the instrument cluster. It is a control module, not just a simple gauge cluster. If you continue to have problems, and they are not connector-related (it usually is), it's going to be the cluster.
Old 13 Dec 2004, 06:55 pm
Today, I was running some errands and I was keeping an eye on the gauges. Looks like by removing the fuse and putting it back solved the problem. I'll still keep an eye on it.
Purple04, thank you for your input.
Regards,
Luis E.
Old 13 Dec 2004, 07:23 pm
Would seem the fuse wasn't seated right, but I haven't heard of that one before. Let us know if it returns.
Old 15 Apr 2005, 01:21 pm
Wow, sorry for the HUGE delay in responding to this post. It's seems to be that by removing the fuse and putting it back again solved the problem. I haven't had any problems ever since December, when I got that problem.
Thanks for your help.
Regards,
Luis E.
Old 15 Apr 2005, 01:53 pm
Glad you are fine. This isn't something I've heard of on PTs, but anyone who has worked on 15-20 year-old vehicles has dealt with poor connections. When I buy a new old car, one of the first things I do after a detail is to check the connections on the battery cables, all connectors, bulbs and fuses. The hyper ground discussed elsewhere has been proven a few times, and older Toyotas are known to be picky about engine grounds.
vB code is On
Weird Noise ptlovr Tech & Performance Forum 7 05 Jul 2006 07:14 am
Dash acting weird Nikkortim General PT Cruiser Discussions 8 04 Sep 2005 06:30 pm
sometime things are weird gonzomania Non-PT Discussions 1 11 Sep 2004 09:14 pm
weird noise NEED HELP!!!!!! skeeter1620 Turbo Performance 1 20 Dec 2003 04:35 pm
weird 'slipping' problem when breaking or driving. hbsurfer6984 Tech & Performance Forum 8 21 Nov 2003 11:10 am
Archive: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44
  Equity Release | Fast Loans | Mortgages | Loans | Myspace Layouts
