Need Help with Fog Lights
Old 18 Dec 2004, 01:40 pm
Default Need Help with Fog Lights
As our PT did not have Fog Lights, I purchased a kit and installed the wiring harness and lamps. My problem is: With the new Multifunction switch the fog lights work, but the turn signals and emergency flashers do not. I contacted the dealer who I bought them from and received a new MF switch. I installed that one and still have the same results.
I have checked and rechecked all of the wire connections and they are all correct to the instructions. Is it possible that both MF switches are faulty, or is there a problem with the instructions?
Old 18 Dec 2004, 03:14 pm
gonzomania's Avatar
Send a message via AIM to gonzomania
Hooligan,
What year is your PT? I installed the fog lights on my 2003 but I had all the wiring. Before I did it some people told me that just because I had the wiring connections by the light itself didn't mean
I had the wiring in the harness on the column. From memory if you unplug the Multifunction switch from the harness there should be 2 light blue wires going to pins in the connector piece. I believe this should be pin 8 & 12 or 14. This means your harness is wired. Other than that check fuses and grounds. I'll keep checking my cd & books.Let me know if you figure it out[:I]
Gonz
Old 18 Dec 2004, 03:20 pm
Hooligan, do the turn signals and flashers work when you reinstall the old Multifunction switch?
That will tell you if a fuse blew.
Old 18 Dec 2004, 03:52 pm
gonzomania's Avatar
Good thinking MD
Old 18 Dec 2004, 04:47 pm
Yes, it does, I had forgot to mention that. With the old switch both the turn signals and Hazard lights works.
Old 18 Dec 2004, 04:50 pm
quote:Originally posted by gonzomania
Hooligan,
Gonzo, I have a 2002, it did NOT have the wiring to the connector in the block that connects into the MF switch. I did have the wiring to the lights but nothing in cavity 13 & 14 which would mean that it was already wired.
Old 18 Dec 2004, 06:20 pm
gonzomania's Avatar
Is your Pt an F series? If it is all the wiring is there. I'm thinking that the wiring harness to the multifunction switch isn't wired you may have to run them. I found the connector and the pins diagram off the cd but I can't copy to post here. If I can figure out how I'll email you with the picture and chart. You can also check on PTDIY. http://www.ptdoityourself.net/tl/tl_12.html#285
Old 19 Dec 2004, 09:49 am
Gonzo: it was a Chrysler kit and came with instructions. I followed thier directions to the letter with the new wiring harness and all.
Old 19 Dec 2004, 10:59 am
gonzomania's Avatar
Hooligan, Sorry I reread your original post and saw you had a new harness. You have me stumped! [:I]
Old 19 Dec 2004, 01:56 pm
Seems odd that two multifunction switches would be defective but I guess it is possible. On the '03's the wire to the left rear turn signal is dark green and red. The wire to the right rear turn signal is brown and red. The light blue wires go to the fog lights.
If the old switch works turn signals with the new wiring harness and the new one doesn't, the fuses and wiring should be correct. You might check the inside of the connector of the new wiring harness and see if the old switch and the new switch have the wires to the turn signals in the same pinouts. If they do, you may have gotten a couple of bad switches. You might try checking the voltage across the dark green/red wire (+) and a good ground (-) with the old switch and then the new switch with them each set to left turn signal on. The old switch should be providing 12 volts (since it is working). If the new switch isn't (it should be working if it is showing 12 v), that would indicate a bad switch.
It almost seems as if the two multifunction switches are not designed for the new wiring harness.
Hella fog lights question PoconoPT Tech & Performance Forum 3 17 Jun 2010 11:28 pm
PT Cruiser 1959 Cadillac tail lights available Marge Classifieds: For Sale/Trade 4 23 Oct 2009 02:31 pm
LIghts, Lights, Lights King_Rob Classifieds: For Sale/Trade 4 20 May 2005 09:14 pm
Problem with fog lights TaylorMade General PT Cruiser Discussions 6 13 May 2004 07:41 am
APC Next Generation Tail Lights Jeff V Exterior Accessories Forum 10 21 Mar 2003 01:17 am
