how to install multi-function switch?
Old 17 Jan 2005, 02:50 am
Default how to install multi-function switch?
I have a 2001 PT Cruiser Touring Edition, and today my fog lights were staying on, even though the turn lever/headlight knob wasn't pulled out, and the headlights in fact were off. After using Google, I came across many people who had the same problem, and they solved it by replacing the multi-function switch.
For the time being, I pulled fuse #8 from the fuse box by the driver's side left knee so that my fog lights would stay off. One person said the part # for a 2001 PT Cruiser is 5073049-AB, and he paid $52. I'd like to know a few things:
1) Does everyone think I need to replace the multi-function switch? Everything else works, just fog lights won't stay off. Sounds like a switch that is stuck in the On position. Could trying to adjust it fix the problem, instead of replacing it?
2) How do I find a part # for this? Is there a web page?
3) How do I install it myself if I go this route? What does installing it entail? Removing the steering wheel column shroud (covering) and some other stuff? Directions anywhere?
Old 17 Jan 2005, 06:21 am
All I can tell you is what I've read...that's it's pretty easy to install a new one. The shroud comes off, a couple of screws that hold the stalk and 1 or 2 electrical connections. From what your telling us, yes, it does sound like the multi-function stalk is your problem. Good Luck.
2000 PT. 100,000 miles, Original Owner
Old 17 Jan 2005, 09:02 am
gonzomania's Avatar
Send a message via AIM to gonzomania
I believe the part # is 5016951AB @ $65.00. You can Check this site: https://www.1stchryslerparts.com/oe_parts_catalog.html I use collision side and it works better. To install remove the negative battery cable, this stops air bag from being deployed. Remove 2 Phillip head screws from the steering column cover. After cover is removed ther are 4 torx screws (I believe they are a 10 or 15 mm torx). Remove the electrical connectors from the back of the switch.Reinstall to new mutifunction switch and tighten 4 torx screwsand reinstall column cover. Hope this helps by the way welcome to the forum.[?]
Gonz
Old 17 Jan 2005, 12:15 pm
Juicy,
The part number you want is 5019712AA lists for around $49, this number superceded the part number Gonzo posted.
Remember to transfer over the combo flasher and wiper switch from the old unit to the new. The combo flasher just unplugs and the wiper switch is attached with 2 screws.
Good luck
John & Terry
"His" - 2002 Inferno Red Touring Edition
"Hers" - 2003 Electric Blue Limited Edition
Del Val PT Cruisers
Old 17 Jan 2005, 02:33 pm
Welcome, Juicy.
Seems you've been taken care of.
You the Juicy from PTE? There's a member Juicy there.
Old 17 Jan 2005, 03:52 pm
Yes, I'm Juicy from PTE. Just making my rounds hoping to get an answer between several PT Cruiser forums. I've had my car 4 years now, no more payments, plan on keeping it until it becomes a money pit, so hopefully another 4+ years. I've really enjoyed this vehicle, very versatile and comfortable. Ordered the switch, it was around $60, will post my installation experience on this same thread. Will be the first DIY I've done to the vehicle!
Old 17 Jan 2005, 03:54 pm
Oh and part # was 5073049-AB, which is what it says here:
http://www.ptcruiserlinks.com/forum/...TOPIC_ID=7383&
I saw several other part #s in different posts on other forums, so either everyone but this guy is giving misinformation, or the part # keeps changing? I don't know the auto parts industry, so I have no idea what to call it.
Old 17 Jan 2005, 04:48 pm
I take that back, I'm Sealab2021 from PTE and PTCruiserClub.org. Juicy was taken on those 2, and I usually go by that nick.
Old 17 Jan 2005, 04:53 pm
Juicy.......I tried to find a post I read somewhere regarding this but couldn't find it. As I recall, there's a relay on the multi-switch for the fog lights that will not come with the new one. It's a small, black, plug-in module. Compare the original to the new one before you set the old one aside and you should find it. The person that posted this info said the install directions didn't refer to this.
Good Luck...
Old 17 Jan 2005, 04:59 pm
Let's say my old one has the black plug-in module, and the new one doesn't. Is it something that I can remove from the old one and put on the new one? Why wouldn't the new one come with it if it's a necessary part? What if that part is the broken item that is causing my problem ... then what?
Error Codes skylight Tech & Performance Forum 6 07 Apr 2007 02:19 pm
Anyone install their own Mopar hitch receiver? crazie.eddie General PT Cruiser Discussions 6 06 Oct 2004 10:15 pm
Multifunction switch for postage Shini Quiet Classifieds: For Sale/Trade 0 23 Sep 2004 10:29 am
Anyone install a throttle switch? Jason_L Turbo Performance 4 25 Feb 2004 06:11 pm
  Debt Consolidation | Myspace Layouts | Storage Lockers | Kamala | Debt Consolidation
