under hood insulation
Old 28 Jan 2005, 11:20 am
Default under hood insulation
Hi anybody know the way to take off the clips that hold the insulation under the engine hood. Do they just pull out ? thanks[:I]
Old 28 Jan 2005, 11:28 am
They have 2 small pop-out clips that pop-out when the things gets pushed IN to the hole. Use a small small set of needle nose pliers and you can grab both pop-outs, pinch them, and the clip falls right out.
You can also use a small screwdriver and do one side at a time. Its a pain.
Good luck.
2001 Patriot Blue 5 spd LE
2007 Black Dodge Caliber R/T AWD
2009 White-Chocolate Platinum model F150 Supercrew 4X4
Old 28 Jan 2005, 03:39 pm
Good luck.
thanks i'll give it try
Old 28 Jan 2005, 08:26 pm
Just be careful that you don't slip and have the screwdriver go through the hole, you'll ding the hood from the underside.[xx(]
John & Terry
"His" - 2002 Inferno Red Touring Edition
"Hers" - 2003 Electric Blue Limited Edition
Del Val PT Cruisers
Old 29 Jan 2005, 01:02 am
You might think about covering the engine with a blanket or something just in case they get away from you.. You can get new ones from the dealer but I seem to remember everyone saying they are alittle on the high side pricewise, for what you get.. Just be careful because they will break
Current Mods: Removing small pieces of paint on the hood and grille by painstakingly driving into flying debris kicked up by preceeding vehicles
Old 29 Jan 2005, 09:37 am
I paid [xx(] almost as much for a few of them as I did for my new nozzles. Must be made out of "Gold plated Titanium" or something!!!
PTurbed
Old 29 Jan 2005, 02:03 pm
Sean is right. I use needle nose to grab the flat part and pull, while sticking a small screwdriver under - trouble is, 80% of the time the clip isn't where you're pushing, so you rotate a bit and try again. You can't see the clips. Pain. [xx(]
Old 29 Jan 2005, 03:18 pm
gonzomania's Avatar
Send a message via AIM to gonzomania
When I painted my washer nozzles I screwed the first one up getting under the hood insulation. I purchased new ones from advanced Auto for about $2.00
Old 31 Jan 2005, 09:18 am
Gonzo,
I tried several types of generic clips from Advance Auto, but couldn't find any that worked right. Do you remember the type of clips or the part number of those that you got that worked?
Old 31 Jan 2005, 06:17 pm
Go to a auto paint supply type store. I got 25 for like $10. I kept a spare set for me and gave the rest away to some of my club members. How cheap can they be for not painting the underside of the hood where the liner is. On my other car, it shines under there like the rest of the car [|)]
Under Hood Insulation mr.troy Classifieds: Want To Buy 0 11 Jan 2007 12:28 pm
Suncoast Creations Hood Pablo Turbo Performance 0 27 Apr 2006 10:12 am
Anyone have this hood? drdave Exterior Accessories Forum 2 17 Jan 2005 07:03 pm
Review: Keystone Single Port Hood (GHD-PT1) Beacon General PT Cruiser Discussions 18 28 Mar 2004 11:34 pm
cowl induction hood turbomangt Exterior Accessories Forum 4 06 Nov 2002 03:35 am
