Dash Rattle
Old 31 Jan 2005, 10:15 pm
Default Dash Rattle
[:I]I have a 2004 with 16,000 on it...I have noticed that occasionally on a rough road there is a slight rattle that comes from the top dash cover area on the passenger side. Everthing seems fine and tight. Anybody out there with simmilar rattles in the dash area and maybe any luck to were they were coming from. Have not taken anything apart yet....
Old 01 Feb 2005, 10:44 am
JGN JGN is offline
I have the same Rattle
have no idea where it comes from
Old 01 Feb 2005, 12:53 pm
I sprayed the seams with silicone spray to see if it was a problem with rubbing...but it was not. Might just pull the cover off to see what is underneath it that may cause a rattle...
Old 01 Feb 2005, 03:44 pm
GW GW is offline
This could be a long shot [:I] but you might look in the glove box. Check for something hard in the bottom or back of it that might rattle or vibrate on a rough road. Just a thought.
GW
Old 01 Feb 2005, 04:44 pm
already did this noise is coming from the top area...thanks
Old 03 Feb 2005, 01:58 pm
JGN JGN is offline
Mine seem to be coming for the top or behind the airbag cover on the passenger side....
I checked my glovebox,,took everything out but if i hit a bump it rattles
Guess I'll have to live with it
Old 03 Feb 2005, 03:12 pm
The standard procedure for this type of rattle is to remove the top and put some foam or double sticky tape under the cover. Pull off both A-pillar moldings and the center console. Remove the screw in the center and remove the cover. There may be some marks where the parts are contacting. Put the foam in the areas where they touch and reinstall.
Old 04 Feb 2005, 07:20 pm
[xx(]Well I had a fun day. I took the dash cover off...I must say that it is not hard at all. Well I could not find anything that rattled. So I took the right side cowl off and low and behold I found it. On the windshield washer bottle on the front are two molded in clips that hold the wiring for the washer fluid motor. The wiring was not in the clips. It was just tangling along the bottle. I installed the wiring in the clips and the rattle was gone...O well at least I know how to take the top of the dash apart.....
Old 05 Feb 2005, 05:53 pm
Removing the cover is fun, and quite simple when it comes right down to it.
Been there, done that!!!
Old 08 May 2005, 03:44 pm
I'll bring this back up.
When you say that you took off the front cowl, what exactly do you mean? How did you get to the washer motor assembly? Through the passenger compartment or through the area at the bottom of the windshield under the wipers or through the engine compartment?
Any help is appreciated, I have the same rattle and it's driving me nuts.
On a similar rattle note, any ideas what the rattle is from the rear when I'm driving down bumpy roads? I suspect something to do with the exhaust, but haven't looked at it yet. It's an '04 GT if it makes a difference.
Thanks!
Carbon Fiber Top Dash Replacement zzrogue Interior Accessories Forum 3 22 Apr 2010 07:44 am
dash rattle 4SPEED General Turbo Discussions 5 02 Mar 2007 12:56 pm
vibration causing dash to rattle Easymover Tech & Performance Forum 3 26 Jan 2006 07:34 pm
Dash top cover bluewasp Interior Accessories Forum 7 05 Jul 2005 02:41 am
Rattle in rear interior compartment! gtobey General PT Cruiser Discussions 6 30 Oct 2002 10:10 am
