| Site Home | Forum Home | Photo Gallery | PT Events | PT Videos | Car Videos |
Here's a simple thing that you could try. If you have 2 remotes, try switching the one that you are using now with your spare. This will eliminate the chance that it's an issue with the signal from the remote.
I once had a parking valet mash the button on my remote so hard that something broke in the button and activated all kinds of problems. [:I] |
I bought the car used and it only had one remote. I changed the battery on the remote and even took it completely out to see if it helped. On the way to work today, not a single lock problem. Talk about fickle. I'd rather just disable the auto locking function if possible and just go manual until I can figure this out.
2002 PT Cruiser LE - PTeazer Hood, front and rear bumpers and grille. \"Factory\" spoiler, white headlights, kumho tires, door sill covers, custom intake, engine wire covers, rear tailight covers and the AUX input module for the tunes. ![]() (For sale, buy me!) |
VK, take my advice and do this.
There are 4 screws holding the door panel to the door. Just look for them. Dont forget the one behind the door handle. After that, the door just Pops off. Start at the bottom, after you get it about halfway popped out, reach up and see if you can feel (or if you can see from underneath) a yellow connector that connects the door pin to the locking mechanism. After you pop that off, go ahead and Lift the door out of the door sill. Then you can see where the door lock switch is attached with 2 philips head screws. Remove that first. If you dont have the replacement already you can just put the door back on and let the wire hang out until you get the part. When you get the part (search the forums for some reliable places,) just plug the switch in, screw it back in, and reattach the door. If you need help, just email me and I can walk you through it.
About to start work on modding my car and making it look even better than it already is! |
I tried taking off my door last night with no luck. Removed the 4 screws and the two from the door handles, but couldn't get the panel to come off. I even used a paint scraper to slide it under the paneling all the way around to see if anything was stuck, still nothing. I had messed around with the settings so the car doesn't automatically lock when it reaches the 10-20 mph speed (I forget the exact) and the problem didn't come back at all yesterday. It didn't happen today either, but now my locks won't work at all, completely dead. I tried getting the dash off, but didn't have any luck after removing the console and screws. I'm going to have to invest in the repair manual, but they didn't have any locally.
The problem you will encounter is that even though you programmed it to not automatically lock when you put the car in drive, the switch will still try to unlock the doors. Even if you take the fuse out....It is quite daunting I know.....but if you gently pull the door will pop off, trust me. If you need help VK let me know. Im here for you
What about the rocker switch on the door for central locking? That work okay?
\'05 Limited Turbo Lite, (Silver, of course)4-wheel ABS, Sunroof, Spoiler, E&G Classic grill, K&N FIPK, BTG duals, rear lowered 1.5\", LED washer lights, $20 catch can, Aoogah horn, Weatherflectors, Sunroof Deflector, Fuzzy Dice, rear logo flames, rear pinstripe graphic, Gen3 Taillights, rear sway bar, hood struts, Strut bar. Traded in \'02 Silver Touring Edition w/87,000 miles |
No locks at all, unless done manually from inside the car. Every once in a while I can get it to lock or unlock once, then it goes back to being totally dead.
| door locks locking/unlocking on their own! | talisman | Tech & Performance Forum | 11 | 09 Mar 2008 06:23 am |
| power door locks | deederz | Interior Accessories Forum | 6 | 22 Feb 2006 06:23 pm |
| Installing Power Door Locks | PTRobert | Sound and Security Forum | 8 | 19 Feb 2006 11:36 pm |
| sun visor broke again and power locks quit!!! | otrqt | General PT Cruiser Discussions | 7 | 14 Aug 2005 10:51 pm |
| Your power door locks ever do this?? | Ripped | General PT Cruiser Discussions | 10 | 09 Apr 2004 02:20 pm |
