PT Cruiser Forum Car Videos
Jeep Parts | Car Rims
EGR Valve?
Old 19 Feb 2005, 09:09 pm
Default EGR Valve?
Where's the EGR valve?
I've never touched mine, and have a slight stumble. I just put in new double platinum Champions ($25 at NAPA), and the old ones were fine, nice light greay & gap about .042 -.044, so doesn't seem that was it. I already have Crane wires, so EGR seems a good idea.
Old 19 Feb 2005, 10:27 pm
CREWZIN CREWZIN is offline
Don,
I looked n my parts book and it shows the EGR valve but I still can't figure out where it's at. In the photo below from my parts book, the EGR system is 025-200 which points to the EGR valve. Maybe you can figure out where it's at. [:I]
Old 20 Feb 2005, 12:35 am
SuGamer SuGamer is offline
Don, you know where it is! If you change the plugs then you had to at least lift the intake manifold up and out the way, right? Well, the "tube" on the back of the intake manifold (the one that has 2 bolts with different bolt head sizes) leads to the egr. [^]
Old 20 Feb 2005, 01:23 am
gonzomania's Avatar
gonzomania gonzomania is offline
Send a message via AIM to gonzomania
QSD,
Email me and I scan my book for you. I'm not as talented as Crewzin.If I posted it they would be way to big
Old 20 Feb 2005, 11:48 am
MX-5 MX-5 is offline
QSD,
I've replaced over a dozen of them on PTs.
The valve is located just above where the engine and transmission seam meets. Removal requires the airbox be removed.
There is the metal exhaust gas tube with 2 8mm bolts and a fiber gasket. The EGR mounts to the cylinder head with 2 10mm bolts and a metal gasket. There are 2 vacuum lines that go to the control solenoid, a black plastic pod moounted under the throttle body. It clips into the TB mounting bracket, and has a 3rd vacuum supply line and 1 electrical connector.
The EGR only comes as a kit, including the solenoid. The cost is under $65. Replacement takes about an hour to R&R the assembly, perform a drive cycle, and clear the codes.
Old 20 Feb 2005, 02:34 pm
Thanks everyone. I guess if I buy one, I'll figure it out by seeing it, once I have a new one to know what I'm looking for. [:I]
At least I know where to look now.
Took it for a test drive - seems the stumble is gone - will know for sure on commute tomorrow. - I'll hold off on ERG.
Old 21 Feb 2005, 06:19 pm
gonzomania's Avatar
QSD,
Have you ever changed your PCV valve[:I]
Old 21 Feb 2005, 09:11 pm
quote:Originally posted by gonzomania
QSD,
Never. Why?
Old 22 Feb 2005, 12:09 am
gonzomania's Avatar
I understand that if the PCV valve spring doesn't operate it can make the car hesitate and miss. It's easy to check and alot cheaper and easier to replace
Old 22 Feb 2005, 08:22 am
Okay, where's that? Isn't it connected to rubber hose? Just haven't spotted it, but then, haven't looked for it. [B)]
Car seemed fine on way in, but PCV valve I've done on other cars - usually cheap and easy to do, so why not?
vB code is On
Check Engine Light came on - code 1188? coolvirus General Turbo Discussions 18 09 Jan 2008 01:14 pm
Painted Valve Covers GLH_TC 16V Vendors & Buyers Forum 2 06 Nov 2003 04:35 pm
obd-II codes Punch General Turbo Discussions 5 06 Nov 2003 02:34 pm
Dirt Cheap Flashing FireFly Valve Stem Lights Big Kahuna Exterior Accessories Forum 0 29 Sep 2001 08:59 am
  Free Ringtones | Web Advertising | Libro infantiles | Loans | Mortgage
