PT Cruiser Forum Car Videos
Car Rims
Plug Wires
  #11 (permalink)
Old 25 Feb 2005, 10:26 am
MX-5 MX-5 is offline
If you search the forum database, you'll find that I was the first PT tech to recieve and install the NGKs that are designed specifically for the 2000 & newer 2.4L & 2.0L cylinder heads.
They are fine for a non-turbo PT engine.
However, they work the same as Champion and Champion were designed for the Chrysler engines and are sold by Chrysler, stocked by Chrysler, and warranteed for 5 years and unlimited mileage BY Chrysler. I will stick with the parts the car was born with.
  #12 (permalink)
Old 25 Feb 2005, 04:44 pm
airevac19 airevac19 is offline
Are 8.5 mm wires a good choice or should I go with the 10mm ones. Are the 10mm wires overkill? I'm going to go with the champion regular platinum plugs over the double platinum (more for cost than anything!)
JW
Tac Evac Bring \'em Back
  #13 (permalink)
Old 25 Feb 2005, 05:47 pm
purple04 purple04 is offline
Doubt our beloved PTs NEED 10mm, but it's your money..
As explaination for the double platnums, old cars had a single coil and the DC spark travelled in one direction. On modern (distributorless) cars, each coil feeds 2 plugs in series. This means the spark travels (for want of a better description) up one plug and down the other. When you pull out the old plugs, notice the wear. That's why if you are going to buy platinum, go double.
vB code is On
Best Spark Plug Wires for 03 Turbo? zzzhuh General Turbo Discussions 10 13 Oct 2005 04:49 pm
spark plug wires dzinman Tech & Performance Forum 1 28 Jul 2005 01:25 pm
no-name spark plug wires Probedude Tech & Performance Forum 9 11 Jun 2005 12:13 am
PERFORMANCE PLUG WIRES 4 GT'Z RODRUN Turbo Performance 4 18 Jul 2003 05:15 pm
PERFORMANCE SPARK PLUG WIRES RODRUN Turbo Performance 1 03 Jul 2003 11:20 pm
  Mortgage Calculator | Credit Card Consolidation | Reno Nevada Real Estate | Loans | Buy PSP
