| Site Home | Forum Home | Photo Gallery | PT Events | PT Videos | Car Videos |
Hey guys,
What size plug wires should i go with from Magnacore? 8.5 or 10mm? Also, what is the advantage of Platnium vs. iridium plus? Thanks!! |
I think 8.5 would be fine; 10mm might just be overkill, but they are nice!
Techinally, the iridium plugs are better and produce a bigger spark, but the double platniums are nice too! But it has been adviced not to use the double platnium plugs turbos.
Black 2004 PT Cruiser GT with chrome accent package, chrome door spears, billet gauge eyebrows, chrome beltline, Autotechnica tail light covers painted body color, TYC by Elegente backup lights and GPS Navigation. Silver dragons on sides and hood. Stage 1! Spark plugs gapped to .040, and installed a set of Crane Firewires. BTG cold air intake, AMX1397\'s Turbo Up Charge Pipe, Boomba Racing BOV, Hallman Pro PX manual boost controller and Mean Green\'s Hyperground Solution. http://mysite.verizon.net/vze247vu http://www.ptcruiserworld.com/Junior
04 cool vanila Limited Turbo ![]() Wife has a 03 limited (Steel Blue) |
Agree w/SuGamer. Just getting better wires puts you better off tahn stock, which don't last.
If you consider irridium, I'd stay away from the ones that don't have same reach as stock and require a ground-down socket to install - my $.02. Don't understand why, but platinum isn't recommended for turbos. I put Champion double platinum in mine and just replaced them after 50,000 miles of use - the old ones looked perfect when I took tehm out.
\'05 Limited Turbo Lite, (Silver, of course)4-wheel ABS, Sunroof, Spoiler, E&G Classic grill, K&N FIPK, BTG duals, rear lowered 1.5\", LED washer lights, $20 catch can, Aoogah horn, Weatherflectors, Sunroof Deflector, Fuzzy Dice, rear logo flames, rear pinstripe graphic, Gen3 Taillights, rear sway bar, hood struts, Strut bar. Traded in \'02 Silver Touring Edition w/87,000 miles |
Don, I read that the double platinum cause the engine to ping and knock more than normal. Don't know why. [:I]
Sue,
I'd like to see the data to back that up. I spent over a year getting the Champion 7440 / 7570 double platinum spark plugs manufactured for the PT. I worked relentlessly with Federal Mogul (Champion). Several thousand double platinum plugs have been installed in PTs all over the world. There are no drawbacks to double platinum plugs in the non-turbo PT. Remember, I worked with Champion on this project in 2000/2001, long before the turbo PT was even a rumor. |
The cylinder pressures and additional heat generated by forced induction can blow out the spark, causing misfires. Copper plugs are the best for heat dissipation. For high boost, use copper plugs and a tighter plug gap. |
| Best Spark Plug Wires for 03 Turbo? | zzzhuh | General Turbo Discussions | 10 | 13 Oct 2005 04:49 pm |
| spark plug wires | dzinman | Tech & Performance Forum | 1 | 28 Jul 2005 01:25 pm |
| no-name spark plug wires | Probedude | Tech & Performance Forum | 9 | 11 Jun 2005 12:13 am |
| PERFORMANCE PLUG WIRES 4 GT'Z | RODRUN | Turbo Performance | 4 | 18 Jul 2003 05:15 pm |
| PERFORMANCE SPARK PLUG WIRES | RODRUN | Turbo Performance | 1 | 03 Jul 2003 11:20 pm |
