PT Cruiser Forum Car Videos
Car Rims
New GT Manifold
  #11 (permalink)
Old 26 Feb 2005, 02:42 pm
it is the manifold. the plastic is lighter and does not hold the heat(heat soak) like cast aluminum. better performance and cheaper but cool factor= 0
i wish i had a polished turbo manifold it really looks awesome [^]
  #12 (permalink)
Old 27 Feb 2005, 03:33 pm
bigtommy83 bigtommy83 is offline
Send a message via AIM to bigtommy83
i'd rather have the plastic intake manifold as opposed to my hot metal intake. As soon as it becomes available, I may have to order one.
\'04 GT 5-speed, Brand X, Air Force One Intake, Custom Flowmaster Exhaust (retired), SRT-4 exhaust no resonators, AGP Wastegate, Crusher Kit, Former Chrome Package, Mopar BOV, Custom Sub Box, Mopar Pillar Gauges, Hood Scoop, MBC, Stage 1, Mopar Stage 1 Springs, Hurst STS
Future Plans: Custom Intercooler Sprayer, 2-tone Paint Job
\"Hondas are like cigarettes, everyone cool smokes them\"
  #13 (permalink)
Old 28 Feb 2005, 12:45 pm
wsd0836 wsd0836 is offline
Thermodynamics 101:
A metal manifold is conductive to heat. It is hot because it is sinking (absorbing) the heat out of the air flowing through it. Thus making the air cooler. A plastic manifold does not get as hot because it does not sink as much heat from the air inside it.
Andrew
  #14 (permalink)
Old 28 Feb 2005, 01:00 pm
have to disagree with ya on that one. the air coming from around the engine on the outside of the intake is hotter than the air inside the tubes. the manifold sinks the heat from outside and heats up the intake charge.
  #15 (permalink)
Old 28 Feb 2005, 01:33 pm
Yes...that might be true if, in fact, the engine bay ambient air temp is greater that the air temp inside the manifold. Fourier Law of Heat Conduction would apply: "When there exists a temperature gradient within a body, heat energy will flow from the region of high temperature to the region of low temperature." Do we know for a fact that the engine bay temperature is greater?
Andrew
  #16 (permalink)
Old 28 Feb 2005, 03:12 pm
yes.
using a thermocouple i measured the intake air charge temperature to be only a few degrees greater than the ambient air temperature outside the vehicle. the intake charge is drawn from outside the engine compartment through the drivers side fenderwell. The intake air has such a high velocity passing through the manifold that it doesnt have the opportunity to absorb much heat from the manifold. if i had an IR thermometer i could measure the surface temps of the engine parts after some highway operation but i can say from experience that it is hot enough to give a second degree burn.
for more info you can look here
http://www.bstockum.com/toohot.html
  #17 (permalink)
Old 28 Feb 2005, 03:27 pm
tangerinedream1845 tangerinedream1845 is offline
well the new is nice BUT you can't do this to it !
Dream Cruiser II
www.londontobayfield.com
Custom Hood Struts ,Mopar Stage 1 Turbo up Grade , Mopar BOV , Bassani duels , Airraid Cold Air Intake , APC body Kit , Billet Grill , APC tail Lights , GTO Pro Beam Headlight Covers, Chrome Bumper inserts , Chrome Door Inserts , Chrome dash eye brows , Chrome gas door , Chrome Antenna Bezel, Custom Flame Job By Yosemite Sam ,
  #18 (permalink)
Old 28 Feb 2005, 04:52 pm
Nice article. You also made a good point: "...intake air has such a high velocity passing through the manifold that it doesnt have the opportunity to absorb much heat from the manifold." The air velocity would have to be rather slow to transfer a significant amount of heat from the manifold. In that case it wouldn't matter if the manifold was exothermic or endothermic since the transfer of heat from the manifold to the flowing air or the transfer of heat from the flowing air to the manifold would be minimal either way. That being the case the material the manifold is constructed of would not matter from a thermodynamics standpoint. Do you agree?
However, in theory, by removing the metal manifold and replacing it with a plasic one, they have essentially removed a large heatsink from the engine block. Thus, concentrating heat in other areas of the bay, and possibly raising the overall temp of the bay. Since now there is less metal to absorb and dissipate the heat...in theory.
By the way, I've meationed this before, but not all '05 GTs have the plastic manifold. My '05 GT convertable has the metal manifold. It's exactly the same as the one in my wife's '03 GT.
Andrew
vB code is On
Turbo plastic manifold on N/A PT? littleblueGT Tech & Performance Forum 4 24 Jan 2007 01:05 pm
Plastic manifold & plugs quicksilverdon General Turbo Discussions 3 21 Mar 2006 12:48 pm
PLASTIC GT MANIFOLD PROBLEMS? littleblueGT Turbo Performance 27 28 Oct 2005 10:14 pm
Turbo manifold question proxeyed Tech & Performance Forum 6 29 Jan 2005 12:55 am
polished intake manifold(( IT"S HERE)) amx1397 Turbo Performance 25 07 Jan 2004 11:35 pm
  Payday Loan | Share Dealing | Web Advertising | Buy PSP | Car Insurance
