Programming the keyless Remote
Old 13 Mar 2005, 01:32 pm
Default Programming the keyless Remote
[:I]
We had to purchase a new keyless remote. But it did'nt come with programming instructions. Can anyone help? It's for a 2003
Old 13 Mar 2005, 03:10 pm
The instructions are in your owners manual in the glove box. If for some reason you don't have your owners manual, let us know and I will post the instructions.
Old 14 Mar 2005, 08:26 am
Welcome.
According to the 2003 Owners Manual:
"You can program new keys to the system if you have two valid sentry keys by doing the following:
1. Cut the additional Sentry Key Transponder blank to match the ignition switch lock cylinder key code.
2. Insert the first valid key into the ignition switch and turn the ignition switch ON for at least 3 seconds but no longer than 15 seconds. Turn the ignition switch OFF and remove the first key.
3. Insert the second valid key and turn the ignition switch ON within 15 seconds. After ten seconds a chime will sound and the Theft Alarm Light will begin to flash. Turn the ignition switch OFF and remove the second key.
4. Insert a blank Sentry Key into the ignition switch and turn the ignition switch ON within 60 seconds. After 10 seconds a single chime with sound. The Theft Alarm Light will stop flashing, turn on for 3 seconds; then turn off.
The new Sentry Key has been programmed. Repeat this process to program up to a total of 8 keys."
Without 2 valid keys, it is back to the dealer for them to reprogram.
Hope this helps:
http://www.ptcruiserlinks.com/forum/...archTerms=Keys
Old 14 Mar 2005, 06:31 pm
I belive Depot3d was looking for instructions for programming the transmitter rather than the key. Page 21 of the 2003 PT GT Manual:
"Up to four transmitters can be programmed to your vehicle. Your new vehicle was shipped with two transmitters. See your dealer for additional transmitters
Additional transmitters can be programmed to the system by using the follow procedure:
1. Insert the key into the ignition switch and turn the switch to the ON position.
2. Press and hold the Unlock button on the transmitter between four and ten seconds.
3. continue to hold the unlock button and press the Panic button. A chime will sound to indicate that the transmitter programming mode has been entered.
4. Press a button on all transmitters to be programmed to the system, including any previously programmed transmitters. A chime will sound when each transmitter has been programmed.
5. Turn the ignition switch off to exit the transmitter programming mode."
Old 16 Mar 2005, 12:55 pm
quote:Originally posted by MichaelDay
...4. Press a button on all transmitters to be programmed to the system, including any previously programmed transmitters. A chime will sound when each transmitter has been programmed.
Does this mean that if one of the origional key fobs isn't there when you program a new key fob, that it won't work anymore after that?
[:I][xx(]
\'03 PT Turbo 2CN
Auto/Stick
Lt. Almond/cloth
Blanes HoodStruts
etc.
Old 16 Mar 2005, 02:09 pm
I haven't tried it that way but the manual could seem to imply that would be the case.
Old 21 Jul 2005, 02:14 pm
Hey guys, just found the forum and it looks like a wealth of info. I have to get a new keyless remote for my newly acquired 2002 LE cruiser and was curious if this same method would work on that model too?
- J. Christian
Old 21 Jul 2005, 02:48 pm
The 2002 should work the same way.
Old 21 Jul 2005, 04:25 pm
Yup.
And welcome to the Forums, JS!
Old 25 Jul 2005, 04:09 pm
vk vk is offline
Will this work if you only have one remote? I know you need two keys to program those. I bought my car used and hate the idea of only having one way to get into the car if I lock myself out. I was thinking of just getting another remote to keep for lockouts if it will work that way.
2002 PT Cruiser LE - PTeazer Hood, front and rear bumpers and grille. \"Factory\" spoiler, white headlights, kumho tires, door sill covers, custom intake, engine wire covers, rear tailight covers and the AUX input module for the tunes.
(For sale, buy me!)
Amp Remote... CHROMEDCRUISER Sound and Security Forum 4 16 Jan 2005 12:39 am
Remote keyless entry and exterior lights circuit f Nawalins Tech & Performance Forum 3 01 Sep 2004 11:44 pm
Exterior lights and remote keyless entry Nawalins General PT Cruiser Discussions 1 30 Aug 2004 07:33 am
Remote start with factory alarm SwtNLwPT Sound and Security Forum 0 14 Jul 2004 10:19 am
Programming Keyless enty tommiesc General PT Cruiser Discussions 8 03 Feb 2004 08:36 pm
