Pt brake light.
Old 13 Mar 2005, 01:38 pm
Default Pt brake light.
Hello there, this is new kid on the block. I am having a small problem that the dealers cannot find when they have it. I have a 2.2CRD touring 52plate with only 24k on the clock.
In the last 6 months the brake light comes on and bongs at me then goes off 5 secs later under acceleration(gentle or hard), cornering(likewise). It does it when it feels the handbrake is def off. Fell like[xx(]. Any ideas anyone. Ohh anyone know where I can get a rear factory spolier cheap. Cheers azman.
Old 13 Mar 2005, 01:58 pm
Check your brake fluid & fill, your brake pads are wearing & the reservoir on the PT is relatively small. It's kind of a warning that your going to need to do the brakes soon. [8]
PTurbed
Old 13 Mar 2005, 02:02 pm
Already done that one which is why I am mightily stumped. Cheers for the thought though. [^]
Old 13 Mar 2005, 03:07 pm
If the brake fluid reservoir is below the full mark, which I suspect it is, try filling it too the full mark. The PT's are noted for having hyperactive brake fluid warning lights. If you add any brake fluid, you will need to keep a close eye on the brake pads to make sure you don't wear them down too much before your light goes on again.
If that doesn't solve the problem you probably have a faulty sensor.
Old 13 Mar 2005, 03:37 pm
Check the brake handle switch too. I haven't heard of it on PTs but on other cars, if the handle is left up a click or 2, the light can be triggered by car movement.
Old 14 Mar 2005, 12:32 am
I have that happen when I stomp on the accel, just for a few seconds.
Old 14 Mar 2005, 08:13 am
Sounds exactly like what I got around 25,000 miles and as PTurbed says - as pads wear, fluid level drops - not to add mark, but enough that when you accelerate the fluid sloshes and sets off low fluid light (and chime).
I just changed pads instead of adding fluid - put in ceramics and eliminated dust. The pads were only 1/2 worn, but light went out and never came back.
At 24,000 miles, I'll bet that's what it is. Have dealer top off fluid or put in new pads.
Old 14 Mar 2005, 02:05 pm
Don't know if you have a 5spd or auto. If you have a 5 spd make sure you are checking the brake reservoir and not the clutch reservoir.
Old 15 Mar 2005, 05:06 am
Cheers guys got it sorted. I was checking the wrong reservoir [xx(] DOH! all fine now. The pads are only half worn so i will keep them for a bit longer. Quicksilverdon where did you get the ceramic pads from matey? sounds like a good idea[|)]
Old 11 Apr 2005, 10:02 am
Rude of me not to reply...
They're Raybestos ceramic pads. I got them from PartsAmerica.Com.
parking brake light going on??? yobiebs Tech & Performance Forum 8 01 Nov 2007 09:25 am
Parking Brake Light upon Acceleration JohnM Tech & Performance Forum 5 27 Jan 2006 09:07 am
Third Brake Light GTTurboMaxx Exterior & Interior Styling 5 25 Jan 2005 02:49 am
Brake Light Warning and chime sound. GTinAZ General PT Cruiser Discussions 14 14 Dec 2004 09:33 am
Parking brake light coming on CHROMEDCRUISER Tech & Performance Forum 8 06 Dec 2004 10:11 pm
