Silencer and tire pressure
Old 21 Mar 2005, 02:34 pm
The filter should be fine. Tire pressure should be checked cold. See owner's manual and door sticker.
Old 21 Mar 2005, 03:04 pm
Agree filter's fine. The K&N just "breathes" better.
Tire pressure 1) is a function of temperature, and 2) all tires lose pressure over time.
If you pump your tires up in the fall, you'll find they'll be down when winter hits. Fill them in winter, and first warm spring day you may find them over.
I check once a month (I drive a lot) and always run mine high (35-36) because I like a firm ride & good mileage.
Tire pressure has a big effect on mileage - find a stretch of road, drive up to say, 40MPH, then take your foot off at a landmark (Tree, building, etc.,) and then look at speed at another landmark. Pump up tires and repeat, and you can see and feel the difference.
The fact your tires are all low the same amount is good, indicates you have no leaks.
Old 22 Mar 2005, 01:12 am
quote:Originally posted by quicksilverdon
...The fact your tires are all low the same amount is good, indicates you have no leaks.
Or, four leaks precisely the same size.
