Trac control, wiper switches on center dash
Old 04 Apr 2005, 02:31 pm
Default Trac control, wiper switches on center dash
Does anyone have all the switches there? If so which ones are there? I have some things I need to hook up & want a clean stealth install( no toggles switches, or push buttons). I have 2 spaces open where the rear wiper, defroster, trac control & some other switch goes. I want to use the factory switches that go there, but i'm not 100% on which ones they are.
Can someone let me know, please.
Also, if anyone has had the center trim off & has disconnected the switches, can you tell me what they look like at the connector. I'm not even sure if they would work.
TIA,
Tom
Old 04 Apr 2005, 02:47 pm
I am quite sure there are only 4 switch spots. From the left - rear defrost, then rear wiper, then a spare, then Traction control. I put my Aoogah horn button in the spare spot on my '02 - my '05 has the exact same layout.
Old 04 Apr 2005, 04:34 pm
The spare spot QSD has is for the headlamp leveling feature on the export PTs.
Old 04 Apr 2005, 04:41 pm
I had two empty spaces so I filled them with an Aooga Horn Button and my under car LED switch.
Old 04 Apr 2005, 05:58 pm
DOn, yeah, ther are only 4 of them. But with the differnet amount of opitions for this thing. I didnt know what all was avail to put there.
CREWZIN, that is exactly how mine is. I want to put the oogah horn buton there & another one for something else. But I want to use the factory switches if I can.
MX-5, that you for the info on the extra switch. SO all the PT's regardless have the one spare spot.
I was thinking of just getting 2 trac control buttons. But I think they are back lit so that may look stupid. Maybe the washer buttons & scrape off the little emblem, so they just look black. I want to keep this as factory looking as possible.
I'm tired of all the little buttons & aftermarket stuff. Because when it breaks & most of the time something isnt available, you have to remodify it. In keeping with stock. If it breaks, I can get a new one & it plugs right in. No hassles. That is what I need right now. No hassles.
Old 04 Apr 2005, 09:38 pm
I'm saving that space for the master arming switch.
Mounting the switch will be easy, as will be installing a thumb-button shift knob
http://performanceunlimited.com/cobr...shiftknob.html
The hard part is figuring out how to mount one of these:
http://www.gdatp.com/products/lethal...u-8a/gau-8.htm
Then just wait 'til the next twit clogs up the left lane
Defend Our Hobby!
Join the SEMA Action Network
http://www.semasan.com
Old 04 Apr 2005, 09:50 pm
I was thinking of something a little more tame.
I am looking for a true 5 horn kit. But dont want to shell out $2000 to get it.
This is kinda like what I have my eye on. But the one I may be getting is $1000( no tthis cheap $300 unit)
http://www.hornblasters.com/
Check Engine Light came on - code 1188? coolvirus General Turbo Discussions 38 25 May 2011 09:01 am
trac control & abs light staying on in dash bobs turbo pt General PT Cruiser Discussions 6 28 Jun 2010 12:09 pm
obd-II codes Punch General Turbo Discussions 13 06 Jul 2009 06:54 pm
