Roaring noise from the rear when reversing?(FIXED)
Old 15 Apr 2005, 02:55 pm
Default Roaring noise from the rear when reversing?(FIXED)
There is a roaring noise that coming from the rear of my car when I go in reverse the 1st thing in the morning. Somtime it would appear when I make a corner going forward. It's very loud at time and sometime not at all. It's an on and off thing. but lately it happens alot more. The only solution I have is quickly pulling the hand and releasing it. a quick jerk and the noise would go away for the moment or the entire day. What do you think?
I have a feeling that it's
1)The rear rotor need replacement.
2)The rear brake caliper need replacement. the thing may lockup and don want to release.
3)something is up with the brake lines
Other than those I couldn't think of other cause
Thanks
Old 15 Apr 2005, 04:26 pm
When I had my '01 there was a noise that sounded like I was running over aluminum when I first started out. Dealer found that my E brake cable had rusted and the rear brakes were not fully releasing when I started out.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 16 Apr 2005, 07:36 am
Does sound like rear brakes, but the e-brake (quite sure) is a separate drum at base of rotor. Sounds e-brake related, not main brakes. Only does it after you've set e-brake overnight?[:I]
Old 17 Apr 2005, 02:51 pm
I fixed the problem. It was the rear brake pad. One of the bad is down to the metal. I had a feeling but I didn't have time until yesterday. A set of rear pads from autozone for $24 and 30min of my time the the problem is gone.
Also I just realized that stuff on ebay cost more than the stuff in stores nowadays so be careful buying of ebay
Rear brake noise... Striker Wheels, Tires, Suspension 4 04 Jun 2006 12:01 pm
mysterious rear knocking noise was found FIXED!!:) Ctown General PT Cruiser Discussions 3 01 May 2006 12:40 pm
Knocking noise from rear end Ctown General PT Cruiser Discussions 9 22 Nov 2005 06:08 pm
Rear end noise... sakigt General PT Cruiser Discussions 5 29 Oct 2003 07:16 pm
clunking noise from rear chrisjensen Tech & Performance Forum 4 02 Mar 2003 06:00 pm
