PT Cruiser Forum Car Videos
Car Rims
Why I don't have a recall for the leaky PS hose?
Old 22 May 2005, 03:33 am
Ctown Ctown is offline
Default Why I don't have a recall for the leaky PS hose?
I just don't understand I have a 2001 LE manual with that power steering leaky hose problem but when I check my vin# on chrysler.com there is't a recall for that problem while I checked other car same year with an automatic they have a recall notice. Obviously I have the same problem too. The PS hose at the bottom of my car is very wet as of now so do you think the dealer will fix that problem even my cars not an automatic and does not have a recall notice?
Old 22 May 2005, 09:00 am
Quite sure the recall was for auto only. The hose rubbed against the casing of the auto. [:I]
Old 22 May 2005, 10:50 am
MX-5 MX-5 is offline
QSD is correct.
The recal is only for the PS hose rubbing against the auto trans case and causing a leak.
You simply have a leaking PS hose.
Either it's rubbed against something else (you don't have an auto tranny case to rub against), the crimped ends are leaking, or the leak is running down the hose from above.
vB code is On
Recall #04V268000 - Engine Fires skylight PT Cruiser News and Rumors 9 28 Sep 2004 06:14 pm
NEW RECALL RE: ENGINE FIRES PTRON General PT Cruiser Discussions 0 04 Jun 2004 04:20 pm
Boost hose blow out, w/ amx1397 mod amx1397 Turbo Performance 0 11 Nov 2003 09:25 pm
Turbo inlet hose Brad Vandrasik General Turbo Discussions 2 19 Aug 2003 03:56 pm
Recall: some 5-speed Turbos skylight General Turbo Discussions 14 17 Apr 2003 11:56 am
  Cheap Samsung LCD TV | Mortgage | Loans | Car Insurance | Internet Advertising
