modification removed and...
Old 08 Jul 2005, 05:08 pm
Default modification removed and...
last weekend i removed my ucp vak and wastegate stage 2 and more power!!! that because my auto tranny can not suport this power i think for i 5 speed its ok but for a auto[V] on the road its ok with all this modification but on the track [xx(]auto tranny is slipping when is shifting stage 1 is just the good set up with an auto tranny dont try to past that range and i know what im talkink about i lost a lot of money[V]
Old 08 Jul 2005, 07:39 pm
Auto should have no problem with S1 level. Did you do the quick learn when you installed the S1? Perhaps there is a problem with your tranny.
Old 08 Jul 2005, 11:38 pm
stage 1 is ok im just talking about with more modification than stage1 auto tranny can not follow that probably the reason mopar dont do the stage 2 for pt cruiser[xx(]
black 2004 limited edition with turbo lite stage 1 mopar bov and boost gauge. prototype power kit. k&n air filter s2 wga ebc greddy profec type 2 http://turbocruiser.monchar.com/
Old 08 Jul 2005, 11:39 pm
my pt run perfect with just the stage 1 [8)]
Old 09 Jul 2005, 06:14 am
My first reaction is to beef up the tranny with tommy's HD trans kit!!
Old 09 Jul 2005, 07:43 am
Send a message via AIM to AZ_IceMan
Hmmm, well I've been running my setup for a while now. Maybe I got a factory freak but my tranny hasn't been slipping at all. Running stage 1 with the stage 2 WGA and the VAK kit UCP and CAI and a 2 stage boost controller with high boost holding at 18. No problems. You might want to consider that 2 stage. My first (low boost) stage I launch at only 10psi so i can get traction and I go easy on the torque converter and then once in 2nd i flip the switch for my added kick in the pants at 18psi. [8)] Plus keep tabs on your fluid. I installed a tranny temp guage and the higher the temps go, the sooner you need to replace the fluid. Living in ARizona, I have to change my fluid about every year and it keeps my tranny safe. so about every 12000 miles or so.[?]
<div align=\"right\"><h2><b><i>Can we say Sleeper?</i></b></h2></div id=\"right\"><div align=\"right\"> </div id=\"right\">
Old 09 Jul 2005, 12:51 pm
This is a very good idea. I alway urge people to spend a little $$$ and keep fresh fluid in their auto trannies. The rate of breakdown of tranny fluid rises almost exponentially with an increase in fluid temp.
Old 09 Jul 2005, 02:21 pm
did you do a lot of races whit your PT
or just hard street miles?
by the way,i'm still interested in your parts.
i'll try to get my email working again.
is the PT for sale?
2004 electric blue turbo touring edition
My simple Airbox modification BumperBob Tech & Performance Forum 8 13 Jan 2005 05:11 am
Suspension Modification Complete.... Gear_Head Tech & Performance Forum 5 02 Jun 2004 01:36 am
Front bumper cover removed CREWZIN Exterior Accessories Forum 15 29 Mar 2004 11:58 am
guages/pod removed Punch Exterior & Interior Styling 11 18 Jan 2004 02:16 pm
Put ....well removed exhaust from the gt ptcruzin42 Turbo Wheels/Suspension/Handling 28 26 Apr 2003 04:42 pm
