Vibration between 40 & 60 mph???? anyone had this?
Old 11 Jul 2005, 03:35 am
Default Vibration between 40 & 60 mph???? anyone had this?
Hey Guys
My PT GT 5 spd 2004 has developed an annoying vibration
between 40 & 60 mph anyone had this
problem or have any idea what it could be??
thanx
[:I]
Old 11 Jul 2005, 04:23 am
quote:Originally posted by gtbright
Hey Guys
thanx
[:I]
Is the vibration in the steering wheel?
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 11 Jul 2005, 07:29 am
Most likely wheels/tires. Start by having a good balance - might have lost a weight. inspect the tires carefully - the Good-for-a-Years have been known to have ply eparation. You didn't just rotate tires, did you? If so, rotate back - that'll prove/rule out tires.
Old 11 Jul 2005, 09:11 am
Tires were just checked for balance all OK
I forgot to note that it only seems to happen when
in gear seems like it anyway????
Thanx again
[:I]
04\' Bright Silver GT 5 spd.
K&N
Old 11 Jul 2005, 11:02 am
Thanx again
[:I]
If that's true, could be a drive halfshaft -you're under warranty, right? Take it to dealer & have it checked out.
Old 11 Jul 2005, 02:57 pm
Yes i'm still under warranty
I'll have it checked out.
Has this been a common problem???
Thanx Guys
K&N
Old 11 Jul 2005, 03:07 pm
Common, no. A few reports, yes.
There have been some posts about the stock Goodyears causing your problem. Also a lot of us have encountered potholes to negative effects.[:0]
Old 11 Jul 2005, 04:15 pm
IMHO the first thing to look at is the way the tires were balanced. I had mine done 3 times by various shops after the dealership put on a new wheel for me. They were using the rim mount weights. Goodyear finally sent me to a America's Tire store. They reconized the problem immediately and rebalance the wheel using the weights that stick on the interior arch of the wheel. Problem solved.
Old 12 Jul 2005, 10:56 pm
I had the exact same problem.
I rotated the tires and it got worst.
When they where at the balancing machine, I noticed the threads going up and down... I asked the tech. He replied they are good, "it is an ilusion on the threads when they rotate..."
I didn't like the response... This month, I installed four new tires, all is smooth all the way to 126.... jejeje.
I bought BFG G-force KDW tires. AA Traction, A Temp, 320 Threadwear...
See my post "New Shoes on my PT" for more Info.
Ian
Old 13 Jul 2005, 12:17 am
I too, had the exact same vibration.
Rotated and re-balanced tires and it is gone. I can drive down straight road with hand off the wheel again.
harmonic vibration rszappa1 Wheels, Tires, Suspension 17 15 Feb 2006 11:39 am
vibration causing dash to rattle Easymover Tech & Performance Forum 3 26 Jan 2006 07:34 pm
40 to 60 mph Vibration Update fixed gtbright General Turbo Discussions 5 05 Sep 2005 06:51 pm
Steering Vibration qimoves Turbo Wheels/Suspension/Handling 6 12 Jun 2005 05:45 am
40-45 MPH Vibration in a new '02 PT Automatic Mopar Madness Tech & Performance Forum 14 31 Jan 2003 11:44 pm
