BOV & P0443 code
Old 12 Aug 2005, 09:57 pm
Default BOV & P0443 code
I just got my upgraded wastegate and boost controller working without setting off the check light, but noticed that the BOV (I have the forge) started fluttering under boost. PCM maybe?? So I put the next stronger spring in it. I went out for test drive and immediately the check light went off, but instead of a 1188 code I was getting for overboost, now I'm getting P0443 code. Purge valve control circuit. Does anyone know if this code is because the PCM cannot lower boost by opening the blow off valve becuase of the stronger spring I installed?? It does blow off when I release the gas for shifting so the BOV is still working correctly, but probably not as much as it did before. Any thoughts...
Old 12 Aug 2005, 10:15 pm
I checked my books and acording to the DC Manual, the P0443 code is not the BOV or anything to do with the turbo directly.
It is an Evaporative emission purge Valve. It is located close to the AC "tie-down-bolts" and bellow the Cruise control valve.
here is the operational description from the manual:
"All vehicles use a proportional purge solenoid (Fig.
2). The solenoid regulates the rate of vapor flow from
the EVAP canister to the throttle body. The PCM
operates the solenoid.
During the cold start warm-up period and the hot
start time delay, the PCM does not energize the solenoid.
When de-energized, no vapors are purged.
The proportional purge solenoid operates at a frequency
of 200 hz and is controlled by an engine controller
circuit that senses the current being applied
to the proportional purge solenoid and then adjusts
that current to achieve the desired purge flow. The
proportional purge solenoid controls the purge rate of
fuel vapors from the vapor canister and fuel tank to
the engine intake manifold."
here are the removal steps:
REMOVAL - 2.4L TURBO
(1) Disconnect the negative battery cable.
(2) Remove solenoid from mounting bracket by
pressing tab and pulling of the solenoid from bracket
(Fig. 3).
(3) Unlock and disconnect the electrical connector
from the purge solenoid (Fig. 4).
(4) Remove the 2 vacuum lines (Fig. 4).
(5) Remove solenoid.
Hope this helps.
Ian
Old 13 Aug 2005, 12:09 am
Yes it didn't really sound like anything to with the turbo but I changed the BOV spring and then got the code so I figured I ask. I changed the spring back but still got the code. So what you are saying is that I probably have a bad soleniod?? Oh boy, now I get to take off my WGA and boost controller so I can get it covered under warranty!! ye ha........@#$%$^$#@#[xx(]
05\' GT Convertible in Metallic Midnight Blue
Mods...
http://www.cardomain.com/memberpage/808143
Please see Forum Guidelines regarding signature image sizing.
Old 13 Aug 2005, 09:00 am
I did the same thing because I had a a P0554, Power Steering Pressure Sensor Circuit Intermittent code.
The funny thing is that this stupid sensor in the Steering gear causes the engine to fluctuate rpm in idle... even the Power steering affects the engine.
I checked it and it had a drop of PS fluid inside the conector contacts causing it to send false readings. It is a small sensor and should be cheap, but i want it fixed under waranty... So this means, don't give them any reason for them to deny waranty repair.
Ian
Old 15 Aug 2005, 05:51 pm
Well, I disconnected battery overnight, checked gas cap, and took soleniod # 2 completely out of the boost control loop and NO problems yet. Only boosting to 14.5 now and will keep it there untill I'm sure I've solved the problem.
Mods...
Old 15 Aug 2005, 06:06 pm
That code is contagious!!!
After I replied to this post, my "check engine" came on and the P0443 code was there!
anyway, the car is going to the shop for other repairs, so I will add it to the list.
Ian
Mopar radio security code. Ian-PT-GT Sound and Security Forum 11 24 Feb 2010 02:19 pm
Code P0300 rszappa1 Tech & Performance Forum 2 30 Nov 2005 12:47 pm
Need diag. code info RIvey Tech & Performance Forum 1 01 Oct 2005 12:05 pm
P1188 Code Gear_Head Turbo Performance 8 08 Feb 2004 01:37 pm
Error Code P0016? tezz Turbo Performance 3 08 Jul 2003 11:36 am
