first oil change and tire pressures?
Old 24 Aug 2005, 03:19 pm
Default first oil change and tire pressures?
Now that I have 3,000 on my '05 GT w/autostick(bought 7/04/05. (hey I like to drive!)..it's time for the oil change. It used almost 1 quart, which from what I read is acceptable. Not really into doing it myself this first time, What's the dealer gonna put in, and doesn't the GT take a different filter/oil ?
Also, got around to checking my tire pressure(205/50r17,stock rubber)...the sticker on the door says 38lbs, I assume at max load cold. Imagine my surprise...22lbs. all the way around. I didn't change it right then, took a 250 mile jaunt...the hot pressure read 28 lb. . So, what's the scoop on pressure? More interested in a smooth ride and tire wear than performance. And when can I switch to Mobil 1 ? or should I ? Now let me go run an errand, turn off that traction control and have to jump in front of that 'BMW sedan....
Old 24 Aug 2005, 03:44 pm
First reads your owners manual. It covers all that you ask...as far as Mobil 1 you can start using it right now. Your tire pressue label is on your drivers door....
Old 24 Aug 2005, 06:12 pm
SRG SRG is offline
Those Good-for-a-year tires you got aren't going to take that abuse that long, you need to pump them up to what the sticker says... plus, do you really want to use MORE gas than needed?
SRG
Old 24 Aug 2005, 10:17 pm
36 psi minimum,
i would put dino oil in it 1 more time,
switch to mobil 1 after 5K.
Old 25 Aug 2005, 07:53 am
Tire pressure is way too low. The tires a flexing (and heating up and wearing ) a lot, that's why hot pressure is up - but pump cold psi up to 38.
Yes, turbos have a longer filter.
I would go to Mobil 1, particularly with a turbo.....
Wifey got free oil changes from dealer on her van - I just put a 5-quart jug of Mobil 1 on passenger side, and they use that.
Old 25 Aug 2005, 08:54 am
You can use Mobil 1 right now. As far as the tire pressure go with what is on the label....
Old 25 Aug 2005, 09:33 am
Use Mobile 1 SuperSyn, K&N Filter and the air pressure that's listed on inside of drivers door.
Old 25 Aug 2005, 10:05 am
Sas Sas is offline
"....I would go to Mobil 1, particularly with a turbo....."
I'm not attempting to start a "dreaded" oil thread here, and this is a question from a PT wannabe owner, but if the manufacturer doesn't call for it, why do you feel it's necessary to use synthetic oil if you change engine oil at the scheduled intervals? Does dino not meet the proper lubrication standards?
Sas
Old 25 Aug 2005, 10:14 am
Dino oil meets Daimler/Chrysler standards, but why in the world settle for "meets" when one can use synthetic which has proven time after time over time to far exceed standards - enhances performance, resists lubricant breakdown & extends engine life?
2005 Turbo Lite, Stage 1, Mopar/Borla cat-back exhaust, Eibach swaybars, Bilstein coilovers, 18/8 TSW Montage wheels with 225/40/18 Exclaim UHPs, LED taillights, K & N drop-in & a few other goodies...
Old 25 Aug 2005, 12:08 pm
Get those tires up to 38psi and put a 5 quart jug of Mobil 1 on the passenger's floor and have them put it in. My dealer doesn't carry it. And yes, the turbo does take a different filter.
tire size change 4SPEED Tech & Performance Forum 0 29 Sep 2006 10:24 am
speedo change 4SPEED General PT Cruiser Discussions 3 26 Sep 2006 07:49 pm
tire change corvairbob Wheels, Tires, Suspension 4 31 May 2005 10:51 am
Tire Size and Speedometer Jetcab Tech & Performance Forum 8 08 Nov 2004 09:58 am
widest wheels gonzomania Wheels, Tires, Suspension 11 27 Jul 2004 01:49 pm
