Hard starting 180HP turbo
Old 06 Sep 2005, 02:59 pm
Default Hard starting 180HP turbo
I just bought a used convertible with the 180 HP turbo. The first few days everything seemed fine. Today, it was having trouble starting. The battery has no problem cranking but something is preventing it from starting.
I understand the gas cap could be an issue and I will check it as soon as my wife gets back. What are other possible problems to look for? Are there any TSBs for that engine?
Old 06 Sep 2005, 03:37 pm
Have you tried the ON/OFF X 3 to check for trouble codes?
A few have reported failed crank sensor issues. Are you handy at checking for spark without shocking yourself? Did your car dealer give you any kind of warranty? 30 days, etc.?
Old 07 Sep 2005, 07:31 am
I'm not familiar with the on/off 3x approach to read codes. Would you care to elaborate. I do have a cheap OBDII reader. I just assumed that if there was a code to be read, the check engine light would come on. What is the code for the crank sensor?
BTW, the whole hard starting issue may be moot. My wife told me earlier that she thinks the hard starting was related to the brake not being depressed. I don't think my GT has that kind of interlock feature but it is such an unconscious behavior, I can't recall.
\'03 GT - No mods
\'05 Convertible Touring Ed. - No mods
Old 07 Sep 2005, 10:19 am
I believe you are correct - if you got no check engine light, you'll have no codes, in fact there are times you can get a check engine light and not have a code, but I don't think it can happen the other way around.
As to the brake interlock (for manual) - I don't think it'd crank - it's like on auto if you're in D - it won't crank 'till you put it in P.
Time to visit a dealer - it's an '05, right? Let them fix it.
Old 07 Sep 2005, 11:45 am
There are some codes that will set but not turn on the check engine light.Generally they don't effect emissions or signify a serious problem. Case in point: I work on Hyundai's also.I had one came in that didn't run right.Check codes and it shows a code for a knock sensor malfunction and the codes has set over 200 times but no engine light.Come to find out a rodent had chewed the wires in half....
And specifically chrysler... I know some SKim codes won't urn on the check engine light.... there are others but you get the picture
Old 09 Sep 2005, 04:16 pm
Well,
I checked my wife car last night. You DON'T need to step on the brake to start it and it started fine for me. However, she swears that this is all she did to help the hard starting problem she experienced. Hmmm, could there be a software bug in the engine chip that is somehow corrected when the brake is pressed?
\'03 GT - No mods
Old 09 Sep 2005, 08:51 pm
May be a fuel pump problem, try turning the key on and pausing several seconds before cranking it over.
02 Silver Classic 5 speed with lots of chrome.
03 Cranberry GT A/S debadged.
Make a fast friend, adopt a greyhound.
Old 10 Sep 2005, 02:56 am
If it starts up right away when it does start up I would leave it alone for now till it rsumes its starting problems. If it hesitates at all when it starts up I would give the stealer a shot at it. I say this cause mine starts up very quickly and never hesitates never!!
Old 10 Sep 2005, 04:39 am
This was an ongoing problem with my GT. At times it would not start the first time but would start the second try. When the engine was hot it always started right up. Most of the time it started up the first time. Took it into the dealer and they couldn't either duplicate it or fix it. Heard other PT turbo owners had this problem, too.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 10 Sep 2005, 01:14 pm
Yeah, we had it on our 2003 GT and for what ever reason it has cleared on its own. Had it to the dealer a number of times, they even changed the gas cap thinking the fuel pressure would bleed down. Works fine now at 30,000+ miles.
Mike
Question: 180HP turbo vs GT quicksilverdon Tech & Performance Forum 36 30 Dec 2004 08:42 pm
Hard starting turbo GGJaguar General Turbo Discussions 6 05 Jun 2004 03:39 pm
180HP turbo lite and 215HP turbo difference. alceryes General Turbo Discussions 27 29 Dec 2003 01:57 am
2003 PT Turbo Review by AUTOTEST FILE Gary04GT General Turbo Discussions 2 12 Jul 2003 09:14 am
Chrysler to Offer New Cheaper GT Turbo skylight PT Cruiser News and Rumors 19 12 Jun 2003 02:04 pm
