Hello! I just purchased NGK Iridiums IX plugs, and 8.5mm Magnecor wires(Dont know if they're a good set, but its too late now) and I was wondering if anybody could tell me how to install them, or know a website that shows me? Oh yea i have a 2003 gt. Thanks
I used the copper anti-sieze on the plug threads, its rated to 1800f on the temperature. Torque the plugs to 13 ft lbs (156 in lbs) to get the proper seal. Don't torque cold plugs into a hot (warm) engine. If the engine is hot, the plugs will be overtight when the temps are equal, and will be a booger when it comes time remove them next time. Install the spark plug ends of the wires first, then the coil end. When you first remove the wires, twist the boot about 90 degrees as you pull it off. On the GT, there is a plastic cover over the throttle cables, it comes off with a clip, you'll need to remove this to get access to spark plug #3.
You better look at the instuction sheet that came with the Magnacor wires. It specifically talks about not putting any type of grease onn the terminals or boot.
I messed up. It actually statea that a very small thin film can be put on the boot but that is it...
I'm surprised no one has mentioned this yet, but REMOVE THE MAP SENSOR.
If this is your first time changing plugs, the boots are likley going to be VERY difficult to get off. You will probably have to yank pretty hard. And in the process, you might just hit the MAP sensor, which is that little dealio sticking out of the passenger side of the intake. It comes out with two torx screws, and goes back in very easy. It's like a 50 or 75 dollar part, and you car will run in limp mode without it.
\"If I had a diesel rig, with a big ol\' blade, courtesy would reign, arguments abate, cuz everyone would know, I\'d SQUASH \'EM LIKE A GRAAAAAPE!\" -- Heywood Banks, \"If I Had a Bulldozer\"
Go to the auto parts store and pick up a 5/8" universal joint spark plug socket and 12" extension. It makes it a ton easier to get the plugs in and out. Make sure the plugs are gapped at .028-.033 with those iridiums. They run better with a pretty low gap. BTW, those are real good plugs and wires, good choice[^]
05\' GT Convertible in Metallic Midnight Blue Mods... http://www.cardomain.com/memberpage/808143 Please see Forum Guidelines regarding signature image sizing. |
I called NGK and they do not recomend the gap that small. They stated that they would not go lower then 0.44 on the iriduim type plug.
I went with the standard NGK gap of .052 and it runs like a top, an electric top at that! With my MOPAR wires and these plugs and my Sun grounding wires ir runs as smooth as an 8 cylinder!
06 GT Auto, Cool Vanila Exterior, Presto Change O 3bl, Cargo Mat and Net, Billet Oil Cap, Yoko Avid 4Vs Tires, 03 GT Wheels, 4 Chrome Door Handle Screw Covers, MOPAR Mud Flaps, H&R Rear Sway Bar, Freedom Strut Tower Bar, Rear Door Sill Covers. |
By the way, it has been proven by companies like Psi-Fi that when you up the boost you will need to close the spark plug gap. .028-.033 gap on the NGK Iridium's is ideal. Don't rely on NGK's customer service. One told a friend that the .052 gap was perfect for our cars, and another told him that the .052 gap was way to big for a turbocharger car and he needed to close the gap if he raised his boost. Either way, I know several people running gap at .028 and they can't stop raving about how strong the car pulls and how smooth the idle is.
Black 2004 PT Cruiser GT with chrome accent package, chrome door spears, billet gauge eyebrows, chrome beltline, Autotechnica tail light covers painted body color, TYC by Elegente backup lights and GPS Navigation. Silver dragons on sides and hood. Stage 1! Spark plugs gapped to .040, and installed a set of Crane Firewires. BTG cold air intake, AMX1397\'s Turbo Up Charge Pipe, Boomba Racing BOV, Hallman Pro PX manual boost controller and Mean Green\'s Hyperground Solution. http://mysite.verizon.net/vze247vu http://www.ptcruiserworld.com/Junior
| spark plugs | ote69 | Turbo Performance | 28 | 11 Jul 2010 09:59 am |
| Installing plugs and wires | amazingarthur | Stage Turbo Kits | 7 | 06 Nov 2005 04:21 am |
| no-name spark plug wires | Probedude | Tech & Performance Forum | 9 | 11 Jun 2005 12:13 am |
| 3/25/05 UPDATE - DONE! - New Plugs and Wires NGK | BumperBob | Tech & Performance Forum | 14 | 31 Mar 2005 01:06 am |
| Spark Plugs and Wires install | TaylorMade | Tech & Performance Forum | 4 | 05 Oct 2004 11:04 am |
