2006 PT GT Autostick
Old 13 Oct 2005, 01:13 pm
Default 2006 PT GT Autostick
I sold my 2002 LE (150hp) and just got a new 2006 PT GT. (1) Does anyone know what mod(s) Chrysler made to get the extra 10 hp (220 to 230)? (2) In my 2002 I used a drop-in K&N filter and drilled about 6 3/4" holes in the bottom of the air box, I noticed an increase in performance and mileage (and sound). But now with the Turbo, should I do the same thing or remove the box and go with the configuraion of something like an Air Raid?
This will probably be the only mod other than using syn oil. Really what I'm looking for is some experienced advice on improving the performance and mileage and to get the "Biggest Bang for the BUCK".
Thanks for any advice.
Old 13 Oct 2005, 03:00 pm
I too tried the holes in the bottom of the box idea. I have a temp sensor mounted in my airbox and that was a real bad idea. Ultimately I sealed it back up and then installed a direct feed to the bottom of the box from the front facia. This solved the "hot box" problem. The intake air is cooler than either stock or the holes solution. Don't look for any "ram air" bs just cooler air and my turbo likes cool air.
Best thing to do IMHO is to remove the silencer in the top of the box, drop in a K&N, replace the airbox to turbo pipe to get rid of the restriction there and get a hard pipe for the IC to turbo pipe. There are a couple available from different vendors. Oh, and stage 1 if it ever comes available from Mopar.
Old 14 Oct 2005, 03:20 am
Yeah, forget about a hot engine air intake. Modify the airbox and get a K&N drop in filter. Get rid of the two silencers in the box and replace the turbo to airbox pipe. That pipe has a silencer in it that narrows down to 1 1/2".
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 14 Oct 2005, 07:18 am
Rumor has it the new "plastic" intake flows better, hench the HP gain.
Old 14 Oct 2005, 10:32 am
Correct. Remember, it's less than a 5% gain...
As to intake - cooler IS better, no question. More air is also better, and I got a deal off a Forum member on a FIPK and went with that for better flow. It has a heat shield, but no question that when stopped I'm getting warmer air, but I figure once I start moving....
If I were you, remove silencers, K&N drop-in & get a true flow-thru exhaust (Cat-back) with money saved on intake. Less back pressure is good for a turbo, too.[?]
Old 14 Oct 2005, 12:09 pm
Thanks, for the info. After I get the 06 PT GT broken-in, I will probably go with the AMX 1397 pipe and the drop in filter. Is their another pipe besides the AMX that you would recommend?
2006 PT GT, Linen Gold with Autostick
Greg
Old 14 Oct 2005, 03:00 pm
http://www.agpturbo.com/customer/pro...&cat=90&page=1
http://www.pt$crew.com/phpBB2/viewtopic.php?t=4753
(remove the $ sign)
I would go with price....
A smooth tube is a smooth tube....
2006 PT Street Cruiser Route 66 Edition skylight PT Cruiser News and Rumors 35 17 Nov 2007 02:39 pm
2006 GT Hardtop with 8" SubWoofer SteelBlueGT Sound and Security Forum 0 11 Nov 2006 02:01 am
Employee Pricing on remaining 2006 PT Cruisers skylight PT Cruiser News and Rumors 0 09 Jul 2006 12:29 pm
2006 PT Cruiser Pics and New Specs skylight PT Cruiser News and Rumors 14 13 Nov 2005 08:46 pm
Chrysler's 2006 Plans revealed.. pt_tom PT Cruiser News and Rumors 7 31 Aug 2004 02:33 pm
