miss under long and heavy throttle loads
Old 17 Oct 2005, 07:46 pm
Default miss under long and heavy throttle loads
hi - i have an engine miss at long and heavy throttle loads (passing gear mode at around 5-6,000 rpms). i'm hoping it may be a bad spark plug wire and not a TPS, MAP and/or O2 Sensor(s) issue. it's a '03 turbo gt with only 15K miles on the clock. anyone experience this type of engine miss?
Old 18 Oct 2005, 12:06 am
Yes and willing to bet it is your spark plug wires. Mine went bad at 12k miles.
2004 TE Turbo Auto (Silver)
Mopar Stage 1 w/ Mopar BOV, Mopar CAI, 2.5\" Dual Outlet Heartthrob Cat Back Exhaust System, Gold Line lowering springs 1.50\" front and 2.00\" rear and APC Gen II Euro Tail Lights.
Old 18 Oct 2005, 02:15 am
on that note [^]- i just ordered a set of Magnecor 8mm Blue Ignition Wires. i'll let you know if these do the trick. if not - it's going to the dealer[xx(] many thanks.
gt model, modified airbox with cold air induction, magnecor plug wires, tyc b/up lenses, chrome grille kit, retro 3d taillights painted steel blue, buick-style portholes, nomad chevy trunk trim, blue interior light strips, and massive turned down diesel-type exhaust tip.
Old 18 Oct 2005, 04:00 am
Had a high rpm miss in my '03 GT. Gapped plugs at .040 and it went away. New wires is a very good thing, too.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 18 Oct 2005, 09:29 am
Please post whether wires cure it - I'll bet they do.
Old 18 Oct 2005, 08:18 pm
I've been plagued by the miss and can't cure it. I've had Magnecor wires on it for about a year now. I've changed plugs once and have changed the gap, but nothing works for me.
Old 19 Oct 2005, 02:50 am
There was a TSB for a high rpm miss, too.
sure - will do. i ordered them through revel enterprises. i hope they arrive sooner than later.
btw: with help from this site, i removed that goofy white air box silencer. i have to say, the motor actually has a bit more zip - and the new throaty sound - is killer.
Old 22 Oct 2005, 01:34 am
the new magnecor wires solved 85% of my high rpm miss. i guess i'll do the spark plugs next. go with platinums???
as mentioned in this site's archives, these wires do yield a smoother idle and better throttle response. overall - i'm happy i got them.
if anyone out there is on the fence about buying a set of these magnecor wires - you should go for it. they are worth the price.
Old 22 Oct 2005, 02:14 am
Do not use platinums in a turbo. A turbo runs too hot. Platinums are excellent in a n/a PT. I used factory Copper Plus gapped at .040. Others are using Irridium plugs but they are spendy and there is no benefit to performance.
  Nike Air Force Ones | Compare UK Credit Cards | Find jobs | Free Advertising | Wordpress Themes
