discoloration of intake manifold
Old 31 Oct 2005, 01:51 pm
Send a message via AIM to ptgt2point4
Default discoloration of intake manifold
a while back there was a post about the intake manifold getting all wierd with colors and what not i had a rag with the K&N filter cleaner drop on my intake and it cleaned it up nice...
Old 31 Oct 2005, 06:54 pm
hi - are you talking about a black carbon-like film?
it almost looks like blow-by, even though the intake bolts are tight (won't budge)...
gt model, modified airbox with cold air induction, magnecor plug wires, tyc b/up lenses, chrome grille kit, retro 3d taillights painted steel blue, buick-style portholes, nomad chevy trunk trim, blue interior light strips, and massive turned down diesel-type exhaust tip.
Old 31 Oct 2005, 07:33 pm
That is the one of the reasons I came up with a flow back catch can and a brass check valve between the PVC valve and intake manifold. I got tired of cleaning the dirt impregnated oil film on the manifold and the other areas. So far it works great and the engine stays clean.
Old 01 Nov 2005, 01:41 pm
I clean my engine and intake using Simple Green and an air hose when the engine is cold. I do not use water to rinse or soak. This works great but I must be careful around electrical connections since the air pressure can drive moisture into connectors. If you must use water on dirtier engines I would suggest putting it in a spray bottle rather than using a garden hose.
I'm sure Gary has a different approach and you can find many of his cleaning tips on this forum.
Turbo Intake Manifold mvandale Classifieds: For Sale/Trade 0 19 Jan 2006 10:18 pm
Torque question for intake manifold on a GT crazie.eddie Tech & Performance Forum 5 29 Oct 2004 04:00 am
DRILLED INTAKE MANIFOLD FOR BOOST GUAGE amx1397 Turbo Performance 6 24 Feb 2004 02:50 am
polished intake manifold(( IT"S HERE)) amx1397 Turbo Performance 25 07 Jan 2004 11:35 pm
Upper/lower intake manifold gasket leak? im4gzs Tech & Performance Forum 14 03 Jan 2004 01:52 am
