I see star clips...no, not HAL9000, me.
Old 13 Nov 2005, 03:41 am
Default I see star clips...no, not HAL9000, me.
anyone know any tricks on removing the sound proof panel material - under the hood?
i see star type clips. is there a special tool to remove these?
i am planning to replace the washer squirters with amber led/squirters. any pics on how anybody else out there routed the wires - would be appreciated. i plan on having them operate with the parking lights/turn signals.
thanks.
Old 13 Nov 2005, 10:25 am
Those little plastic star clips aren't made to come off and on, but if your careful you can reuse them. The shaft that goes into the hole has barbs on them and grabs onto the hole really well. Then get a needle-nose pliers behind the star in front of the blanket and gently pry the plug out with some force..but not too much. If you do break a couple, Chrysler sells them or you can pick some up at a flea market where's someone's selling tools.
As far as the wires go....I routed them all over to the rubber hose from the washer and down into the engine compartment. I covered both the wires and rubber hose with a wire loom. Seperate the wires and attach both black ones to any good source of ground. The white wires go together and routed through the engine compartment to the front drivers side lights. Access panel in the wheel well. Look for the black with green stripe wire to the parking light. That's the hot wire and splice into that wire. The washer light will now come on when the parking lights do.
P.S. After you ground the black wires, put the white ones together and touch the positive post located at the end of the engine compartment fuse box. The washer lights should glow and you know the bulbs and wires are good to that point, then continue to route the wires to the parking lights.
2000 PT. 100,000 miles, Original Owner
Old 13 Nov 2005, 02:55 pm
many thanks crewzin! this info is exactly what i was hoping for.[^]
gt model, modified airbox with cold air induction, magnecor plug wires, tyc b/up lenses, chrome grille kit, retro 3d taillights painted steel blue, buick-style portholes, nomad chevy trunk trim, blue interior light strips, and massive turned down diesel-type exhaust tip.
Kerry requests silver star for Katrina satellite66 Non-PT Discussions 68 21 Sep 2005 04:54 pm
Silver star bulbs,waranty prob, my headlight prob CruiserDan Tech & Performance Forum 6 14 Jul 2004 01:16 am
Anybody make pillar pod with clips? wyzard Interior Accessories Forum 6 04 May 2004 08:01 am
5 STAR ? 2sb Non-PT Discussions 9 12 Sep 2003 01:51 pm
(Non-PT) See Star Wars renichms General PT Cruiser Discussions 4 21 May 2002 05:28 pm
  Debt Consolidation | Debt Consolidation | Premium wordpress themes | Indian television shows news | Debt Consolidation
