PT Cruiser Forum Car Videos
Car Rims
Intermittent oil warning light pt2
Old 17 Nov 2005, 10:54 am
sawdust123 sawdust123 is offline
Default Intermittent oil warning light pt2
I have this continuing problem with an intermittent oil light. The problem is that the light stays on after starting the car. If I shut the car off and restart it, the light stays off.
I brought the car to the dealer twice for the problem. The first time they didn't find a problem, they thought it may be caused by cheap aftermarket oil filters. I upgraded the filter I was using and the problem continued. The second time they examined it they said the insulation on the wire from the oil sender unit was getting bare and their could be an intermittent short circuit. I didn't buy the explanation but they did the work under warranty. The problem came back.
Now I think I finally see a pattern. The problem seems to occur when I'm in a rush. The light seems to stay on when I quickly shift the car out of park (I have the autostick) before the light has had a chance to go out on its own. This sounds like it may be a software bug in the OBD code. Has anyone else seen this?
Old 17 Nov 2005, 12:10 pm
Haven't seen anyone else on any forum with this problem.[:I]
Seems you're onto something if you can find conditions that cause it, they should be able to fix it.
Old 17 Nov 2005, 03:45 pm
pppt03turbo pppt03turbo is offline
hmmm, sounds like the actual sending unit to me. why didn't those imbeciles at the dealer change out the sending unit in first place? - instead of wrapping the wire with extra tape...[xx(]
the oil filter suggestion they offered is lame, as well. all filters either meet or exceeds factory specs - unless the oil filter is from china.
i don't think it's a bug in the obd code. if it was a software bug, this problem would be more widespread and a tsb would have been issued. (my 2 cents)
gt model, aftermarket air cleaner, magnecor plug wires, tyc b/up lenses, chrome grille kit, retro 3d taillights painted steel blue, buick-style portholes, nomad chevy trunk trim.
Old 17 Nov 2005, 08:15 pm
Mel K Mel K is offline
I have had the same problem. Every once in awhile the oil light stays on, but if you shut it down, it goes off on restart. I have just learned to live with it and check the oil every now and then. The oil is always at the top of the full line.
Please see Forum Guidelines regarding signature image sizing.
Old 17 Nov 2005, 09:13 pm
littleblueGT littleblueGT is offline
I had that same problem. I purchased a new oil pressure sending unit from the dealer for around $16.00/ I purchased a special socket at Pep Boys in the help section for Chrysler sending units (deep socket). You won't get the old one out, or the new one in without it as there isn't much space. Good luck.
Old 22 Nov 2005, 10:19 pm
bobs turbo pt bobs turbo pt is offline
had the same problem on my first 03 gt they never could find the problem , then the car kept going into " safe mode" but that was a different problem, keep bringing it back to the dealership!! they have to fix it good luck keep us posted
Old 24 Jan 2008, 11:15 pm
lulu2311 lulu2311 is offline
Default Re: Intermittent oil warning light pt2
this is strange because i have the same question now. i test drove a 2004 today with this same problem and i was wondering if i should reconsider purchasing for this reason.
Old 25 Jan 2008, 04:21 pm
soonercruiser's Avatar
soonercruiser soonercruiser is offline
Cool Re: Intermittent oil warning light pt2
Ah ha! You found it LuLu.
I had the same intermittant oil light problem with my 1997 Dodge Caravan. Decided to just live with it also, and keep checkin' that oil level. (especially after the warranty had run out)
Old 25 Jan 2008, 05:10 pm
Mean Green Mean Green is online now
My '03 GT did it a few times if I didn't wait for the fuel pressure to build up and started the car too quickly. Turn the key on, but do not actually start the car for a few seconds. After a few seconds start the car and I'll bet the oil light will not come on then.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 26 Jan 2008, 02:48 pm
good idea mean green !!
vB code is On
Warning light at acceleration PT-ERA Tech & Performance Forum 8 22 Nov 2005 05:54 pm
Intermittent oil warning light sawdust123 General PT Cruiser Discussions 10 12 Mar 2005 04:45 am
Brake Light Warning and chime sound. GTinAZ General PT Cruiser Discussions 14 14 Dec 2004 09:33 am
remove air bag seats= air bag warning light? Punch Exterior & Interior Styling 7 02 Jan 2004 11:23 pm
warning light 2002 chrysler Tech & Performance Forum 2 19 Aug 2002 02:55 pm
  Locate Printers | Secured Credit Cards | Personal Loans | Personal Loans | Credit Cards
