Msd Ignition Better or Worse?
Old 21 Nov 2005, 12:52 am
Default Msd Ignition Better or Worse?
Hi, I have an 05 cruiser convertible with the NA engine. I am probably one of the easiest drivers around on these things. It is a 5 speed car. Gas mileage is always at 27 MPG at the best and it is a dog on performance. I got beat by an early 90's Honda Civic with two people in it the other day. It was just me in the cruiser. I also have an 04 Neon SRT-4, what a blast! It will tear up about anything on the road. I can pull 33 MPG on it without the air on and 27-28 with the air on and hot rod it a little. I know of other cruisers pullling 30-32 on Hardtops loaded down with people. Is there anything I can do to get better mileage. I was looking at an MSD DIS-2 ignition hoping I might squeeze a little better MPG out of it. Any Experience on this? At this point I am looking at putting the turbo engine in the car. It would be much more fun to drive even if I only got 28 MPG. I a wondering if the car is just too much for the motor and it is having to work too hard to just get around. I have the donor GT cruiser so that's not a problem. Any comment would be appreciated.
Old 21 Nov 2005, 09:50 am
All these things will help a tad:
Pump up the tires - go a few psi over teh door sticker & check them often
Synthetic oil
An air intake - or at least remove the "donut" in the stock filter
free-flow exhaust
I would vote against the MSD ignition - but encourage you to get Champion double platinum plugs & Crane wires (RaceAdnStreet.Com) - the stock coil is fine, but stock wires are crap.
as to turbo engine - it's more than that - the wiring harness, computer,....
I'm getting around 25 with my turbo lite and automatic - overall.
Old 21 Nov 2005, 01:54 pm
The only way that ignition upgrades will improve your mileage is if you have big problems with the stock set-up. You are most likely burning ALL the fuel being injected into your engine with nothing wasted now. If you were to have unburnt fuel that amounted to the size of a bb per mile you would have a "check engine light".
Do ignition coils burn out? crazie.eddie Tech & Performance Forum 15 29 Oct 2004 02:19 pm
Ignition coil choices? snakepitt1 Tech & Performance Forum 16 17 May 2004 05:09 pm
Ignition Questions....need help. spark plugs ptcruzin42 Tech & Performance Forum 5 15 Mar 2004 08:39 pm
Key stuck in ignition Tabitha Tech & Performance Forum 7 16 Sep 2003 01:03 am
