Hesitation at highway speeds
Old 15 Dec 2005, 07:50 pm
Send a message via AIM to Blue Streak
Default Hesitation at highway speeds
My '03 GT (autostick) is hesitating when I'm cruising at about 50-60mph (in D) and trying to pass. The car acts like it can't decide whether or not to downshift and sorta "bucks" for lack of a better term. If I punch it it immediately drops down and takes off, but if I just ease into the throttle, it's like riding a mechanical bull. This only seems to happen in this speed range. Anyone else experience this and/or have a solution? [:I]
Old 15 Dec 2005, 09:01 pm
Send a message via AIM to ptTurbo528
YOU KNOW I SUFFER A SIMILAR PROBLEM BUT MINE DOES IT CRUISIN ABOUT 35-40 BUT ILL BE 3RG GEAR IN THE AUTOSTICK AND WHEN I GRADUALLY PUSH ON THE THROTTLE IT DOES THAT MY CONCLUSION WOULD BE A TUNE UP NEW SPARK PLUGS...WHEN I DO MY TUNE UP IM GONNA DO NEW PLUGS AND WIRES AND THE REASON BEING IM UPGRADING MY PLUG WIRES TO A 10MM PLUG WIRE INSTEAD OF THE STOCK 8MM..FOR A COLDER SPARK AND A LITTLE MORE PERFORMANCE...SO YEA IF YOU WANNA DO A MINOR TUNE UP JUST CHANGE THE PLUGS AND YOUR PROBLEM SHOULD AND MORE THAM LIKELY GO AWAY...GET ME POST AND LET ME KNOW WHAT YOU FIND OUT BUT THAT IS MY IDEA ON THE HESITATION AS A FORMER AUTO MECHANIC
03 gt painted steel blue,
goldline coil springs custom exhaust done by yours truly..k&n typhoon intake..tinted windows member of ptcruiserclub.org..adjusted wasetgate. E&G classic billet grille. 600w alpine amp,2-twelve alpine typeR subs,alpine headunit.xeon headlights,fog lights.apc carbon fiber taillights. royal purple oil. k&n oil filter,mopar bov conversion,BTG strut tower brace....
Old 15 Dec 2005, 11:07 pm
my '03 gt did this under load (passing gear/high rpms). a new set of copper champion plugs and a set of magnecore spark plug wires did the trick. i'm 99.9% sure that if you install new quality plug wires and 4 new champion copper spark plugs gapped at 0.40 -- your problem will be solved.
gt model, modified airbox with cold air induction, magnecor plug wires, tyc b/up lenses, chrome grille kit, retro 3d taillights painted steel blue, buick-style portholes, nomad chevy trunk trim, blue interior light strips, and massive turned down diesel-type exhaust tip.
Old 16 Dec 2005, 04:18 am
Ouch. Please don't use all cap letters. Hard to read and is considered shouting.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 16 Dec 2005, 07:04 am
After I replaced my stock plugs and plug wires with NGK Iridium and MOPAR high performance wires my car has run silky smooth.
Old 16 Dec 2005, 07:08 am
I changed out my wires and coil with aftermarket parts. I gained alot more throttle response and the accel was more smooth and seemed a hair quicker. Also idling seemed a little less jumpy I guess you could say... don't know how else to describe it.
2001 Ltd Ed. Inferno Red PT, many mods, many more to come.
Old 16 Dec 2005, 11:29 pm
Cool. Thanks everyone for your advise. Guess I'll try some new plugs and wires and go from there. Start with the cheapest fix and work up, right?
Jeremy
Old 17 Dec 2005, 09:41 am
Well, I wouldn't go cheapest - the stock wires are crap - best for the money are Cranes from RaceAndStreet.Com. Also, Champion now has irridium plugs #9403 - Sparkplugs.com.
Bet the wires & plugs cure your problem...[?]
Old 17 Dec 2005, 11:28 am
let us know how it turns out, good luck !!
Old 25 Dec 2005, 03:43 am
Agree with all above, and Mopar also makes a better plug wire for the PT Cruiser. It's part # P4876511.
\'03 PT Turbo 2CN
Auto/Stick
Lt. Almond/cloth
Blanes HoodStruts
etc.
Idling Hesitation Ken Swenson Tech & Performance Forum 13 30 Jul 2009 08:18 pm
Emission sensor on, engine hesitation higear4 General PT Cruiser Discussions 6 25 Jan 2006 07:09 pm
Slight hesitation DMW General Turbo Discussions 3 03 May 2005 03:36 am
Hesitation Mean Green Turbo Performance 6 31 Dec 2004 08:42 pm
hesitation JST CRZN Tech & Performance Forum 6 23 Oct 2001 04:49 pm
