Wish me luck
  #11 (permalink)
Old 24 Feb 2006, 09:32 pm
quote:Originally posted by CREWZIN
quote:Originally posted by Mean Green
How do they do a 4 wheel alignment when the rear is a solid axle? The dealer did only a front end alignment when I had Eibach springs installed.
Mean Green,
Just had mine done at the dealer a couple months back. I wasn't allowed in the alignment bay to see for myself but the mechanic told me that the PT can use a 4 wheels alignment. If the back is out of spec, shims are needed for correction. Was he pulling my leg to get extra bucks? [:I]
I'm not sure. When I had the alignment done on my '03 at a tire store I was charged for a 4 wheel alignment. When I had an alignment done for the '03 at the dealer they did a front end alignment.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
  #12 (permalink)
Old 25 Feb 2006, 02:49 am
My dealer does offer both front and 4 wheel alignments. The shop I worked at only did 4 wheel alignments and if only a front wheel alignment was needed you still got a charge for the 4 wheel.
2004 TE Turbo Auto (Silver)
Mopar Stage 1 w/ Mopar BOV, Mopar CAI, 2.5\" Dual Outlet Heartthrob Cat Back Exhaust System, Gold Line lowering springs 1.50\" front and 2.00\" rear and APC Gen II Euro Tail Lights.
  #13 (permalink)
Old 03 Mar 2006, 08:48 am
Ye sthe rear can be aligned. It is a Major PITA. the shims are cut & stuck between the axle & wheel hub. There is a cahrt to tell you where to cut & rotate the shim. They basicly take as good a guess as possible & then put the whole thing together to check it.
If they miss, they have to take it apart & do over. Cost me some $$$ to have it done last month. was not covered from the accident. I'm, gonna fight that with the lawyers.
Anyway, it's now done & perfect!
04 GT 5 spd, S1, Mopar Sways, Eibach springs, Airbox mod, K&N drop-in filter, AGP & AMX hard pipes, debadged, PTeazer grill, bumperette, rollpan, Cowl Induction hood & other assorted painted parts!!!
My luck KingKole02 Tech & Performance Forum 11 09 Dec 2004 01:53 pm
If I didnt have bad luck... JaxPT Non-PT Discussions 11 26 Jan 2004 03:32 pm
Bad Luck for Me....... Gear_Head General Turbo Discussions 20 22 Nov 2003 03:50 am
