Plastic manifold & plugs
Old 20 Mar 2006, 11:49 am
Default Plastic manifold & plugs
Okay, I'm told you can change plugs without taking the manifold off with a swivel socket...
Well, that's true for 3 out of 4....
The plug to left of center (# 2) I couldn't get socket on - there's a rib on the manifold in the way - the rib is reinforcing (not a seam) and I'm considering taking a Dremel to the rib...
Anyone changed plugs on a plastic manifold? What's the trick?[:I]
Old 20 Mar 2006, 05:42 pm
I think it takes a second universal joint on top of the swivel socket. but I haven't had to mess with my plugs since I put in the manifold.
05\' GT Convertible in Metallic Midnight Blue
Mods...
http://www.cardomain.com/memberpage/808143
Please see Forum Guidelines regarding signature image sizing.
Old 21 Mar 2006, 09:53 am
I HAD a second universal on the swivel socket...
I did it last night. Took a Dremel to the rib - it was about 1/2" -right on the centerline of where the plug is - I used a sanding drum that melted the plastic and left a rib about 1/8 - 1/4 " - it was enough, and then it was quite easy.
One more tip - the socket rubber would grap the plug and when I went to pull out, the universal would unclip from the socket - I took a thin strip of duct tape, put it on the end of the universal, shoved it into tthe socket swivel, and they were hard to pull apart - worked like a champ.[?]
Old 21 Mar 2006, 12:48 pm
That's a valuable bit of information, Don [^]
Thanks,
Brian
\'03 5-speed S2 Dream Cruiser #1582 w/MP Stage 1 & BOV. Plastic Intake Manifold, rear Eibach springs and Supertrapp axle-back exhaust.
Crane 8.5mm FireWires & Champion Copper Plus plugs, K&N drop in filter. Chrome Plastic AMX TTAB pipe.
(Metro Detroit Area)
PLASTIC GT MANIFOLD PROBLEMS? littleblueGT Turbo Performance 45 25 Nov 2011 12:10 pm
spark plugs ote69 Turbo Performance 28 11 Jul 2010 09:59 am
Turbo plastic manifold on N/A PT? littleblueGT Tech & Performance Forum 4 24 Jan 2007 01:05 pm
Plastic Manifold in Summer? littleblueGT General Turbo Discussions 4 22 Jun 2006 10:10 pm
question about plastic intake manifold steve smith Turbo Performance 32 22 Mar 2006 11:23 am
